Sponsored by The Tire Rack
Old 10-17-2012, 11:14 PM   #1
Trevor330Ci
My Ride: 2001 BMW 330Ci
Send a message via AIM to Trevor330Ci
Tire question
Will the e90 17" style 161s fit on my 01 330Ci convertible?
Sorry If I sound like a noob but never delt with tires/rims before!
01' 330Ci Vert
-Angel Eyes
-Eagle Eyes
-HID Fogs
-K&N Intake
-Refreshed Cooling System
-Smoked Wheels
-LED Interior
-(2) 10" Pioneer Subs
-JBL Audio751Watts Amp
-Kenwood 6.75" Front Mid Bass
-Kenwood 5.25" Rear Mid Bass
-Infinity 1'' Rear Tweeters
-Smoked Side Markers
-Clear Corners
-Magnaflow Exhaust
Trevor330Ci is offline   Reply With Quote
Old 10-18-2012, 03:11 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
More of a wheel question not tire but yes it will fit just fine.
Old 10-18-2012, 10:50 AM   #3
hummer
My Ride: 2001 330CI
Wheels go by bolt circle diameter, hub diameter and offset. These need to be compatable.
Old 10-18-2012, 11:43 AM   #4
jdstrickland
My Ride: '94 325iC & '00 323i
http://felgenkatalog.auto-treff.com/
According to this page, the ET is a bit small, the result will be that the wheel will be pushed outboard a few millimeters -- compare the specs of the wheels you already have. The concern here will be that the tires can hit the fenders -- a slight possibility in the back, no chance in the front -- and you can determine if this will happen by looking at your current clearance and wheel specs.
If your current wheel is a 7.5x17, and the Style 161 is an 8x17, then the new wheel is 13mm wider. Your current ET is 41, the new ET is 34, this moves the tire outboard another 7mm. The 13mm width is split from center, and the ET is measured from the center. Half of 13 is 7, plus 7 means the new outboard edge will be 13mm out from the current. If you can estimate that the new outboard edge will fit into the fender without hitting anything, then you are golden. Basically, if you can fit 2 or three fingers between the tire and the rear fender opening now, then you will fit 1 or 2 fingers with the new wheel package. I say you have no trouble.
Old 10-18-2012, 02:39 PM   #5
Trevor330Ci
So I tested it and I can fit about 2-3 fingers all around
My fingers are kinda big so someone else could probably fit 3 all around
01' 330Ci Vert
-Angel Eyes
-Eagle Eyes
-HID Fogs
-K&N Intake
-Smoked Wheels
-LED Interior
-Clear Corners
-Magnaflow Exhaust
Old 10-18-2012, 04:14 PM   #6
Trevor330Ci
Will a 255 tire fit or can I put those wheels in a 235 or 225?
01' 330Ci Vert
-Angel Eyes
-Eagle Eyes
-HID Fogs
-K&N Intake
-Smoked Wheels
-LED Interior
-Clear Corners
-Magnaflow Exhaust
Old 10-18-2012, 09:30 PM   #7
Trevor330Ci
Never mind thanks for info guys!
01' 330Ci Vert
-Angel Eyes
-Eagle Eyes
-HID Fogs
-K&N Intake
-Smoked Wheels
-LED Interior
-Clear Corners
-Magnaflow Exhaust
