Sponsored by The Tire Rack
Old 10-17-2012, 11:17 PM   #1
boongsin12
My Ride: none
A quick question.
Feel free to answer and reply with your opinions.
Edit: car is 330ci.
From this picture, do you think the tires will rub on fender?
I bought these wheels 18x8 ET40 and ET20, by mistake, and I don't want to go through the hassle of selling them and buying new ones. The rear pair is so far the biggest concerns I have as the offset is a little too low.
The pictures show rears installed on the car.
Left
Right
I appreciate your input!
boongsin12 is online now   Reply With Quote
Old 10-17-2012, 11:27 PM   #2
peytonracer4
My Ride: '00 328i
at that height probably not. lowered? yes.
just go really fast over a dippy road and report back. it won't ruin your car.
Old 10-17-2012, 11:32 PM   #3
boongsin12
My Ride: none
Not lowered, Stock sports suspension.
Old 10-17-2012, 11:38 PM   #4
steve.k
My Ride: 325Ci
No
steve.k is offline   Reply With Quote
Old 10-18-2012, 12:40 AM   #5
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Like I said in your other thread about this, your tire size is incorrect.
In the front you'll never rub. In fact, I'd be more worried about clearing the suspension if you ever go aftermarket.
In the back 99% chance you'll never rub with that tire, 100% chance with the correct profile tire.
Stiggles is offline   Reply With Quote
Old 10-18-2012, 02:12 AM   #6
MercForHire
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
It will rub occasionally over a bump. No big deal.
My e39 rims been rubbing like that for more than a year. No damage done. Love the stance
Oops! My Water Pump Broke Again .................... Coolant in a Bottle
Old 10-18-2012, 02:38 AM   #7
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Maybe the et20 wheels
Old 10-18-2012, 04:04 AM   #8
ImolaSix
My Ride: '02 330Ci M-sport
+1
The correct tire should be a 225/40/r18 not 225/45/r18.
ImolaSix is offline   Reply With Quote
Old 10-18-2012, 06:56 AM   #9
MJLavelle
My Ride: 2001 BMW 330ci
Unless you regularly haul 2 or 3 really big girls (or guys, or shemales, whatever rings your bell ) around in your car all the time, you should be fine. Now,if you lower it, or switch to an aftermarket suspension, you may have issues with some rubbing.
Now, as far as how it looks, it is not so great for me. But I am not the one witha set of wheels that I am stuck with. If I was, I guess I could learn to love it. Judging from the tires, I am guessing this is a winter set-up. If so, just hope for an early spring.
But, like they said above, you should get some 40 series tires as soon as possible.
If you already have them on the car, why haven't you tested it out by wailing away on the car a little? It is not like you would not hear them rubbing. It should be quite noticeable inside the car.
MJLavelle is online now   Reply With Quote
Old 10-18-2012, 02:19 PM   #10
boongsin12
My Ride: none
Lol,, I was hoping you would forget about the wrong size.
Good catch. I know, but I think these have good tread left on them and I am more concerned about rubbing the wall than what's correct and not. As long as they don't rub, I could leave with it. When things look better in near future, I will definitely consider the CORRECT size tires.
Old 10-18-2012, 02:22 PM   #11
boongsin12
My Ride: none
These are the et20 wheels
No I don't have anyone in my car I wish I had done that. But I didn't have enough time and I just wanted to make a quick check, I will definitely make double sure in near future.
Thanks!
Side question:
Does it mean you can fit M3 wheels with low offset? Or not?
Old 10-18-2012, 03:32 PM   #12
Stiggles
Stiggles's Avatar
On a coupe with fenders rolled, yes. Without modifications, you'd need 4 front M3 wheels to run squared.
Sent from my LG-P999 using Bimmer App
