Old 10-18-2012, 06:24 AM   #1
GideonvN
My Ride: BMW 318i E46 touring
BMW e46 318- leaks/ burns oil.
I have replaced ; oil filter seals/ oil filter housing gasket seals. The car still burns 2 quarts a month, however it seems to be smoking even more than previously. Any suggestions?
GideonvN is offline   Reply With Quote
Old 10-21-2012, 09:25 PM   #2
trive2
My Ride: 1989 BMW 535i
Clogged PCV increases crankcase pressure and causes all sorts of leaks. Those engines are horrible for oil leaks.
How many kays? Done a compression test?
trive2 is offline   Reply With Quote
Old 10-22-2012, 06:36 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Oil separator.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 10-26-2012, 12:56 AM   #4
GideonvN
Thank you for the reply, the car is a 2002 318i, with 225 k mileage.
1: can I replace the PCV, as a simple DIY?
2: The oil separator, I will look into.
Old 10-26-2012, 02:03 AM   #5
TitanSilverE46
My Ride: 2001 318i & 325i
I am in the market for a 318i and had a chat with my Indy who services my 2001 325i and 1993 525i (which is what I am replacing).
His advice was; Stay clear of the N42 2.0L engine, Burns Oil, lots of Vanos problems, Get a pre 09/2001 318i with the M43TU 1.9L engine ... bullet proof in his opinion. 200,000km just run in!
TitanSilverE46 is offline   Reply With Quote
