Old 10-18-2012, 12:33 PM   #1
biMMer4.4i
My Ride: 2002 330i
Seatbelt Question
I have a 2002 330i with the airbag deployed light on that was diagnosed as a result of a faulty recieving end of the seatbelt drivers side. I don't know how they are related but if I were to get the same part off a different car would it work or still throw the same code and leave the light on?
biMMer4.4i is offline   Reply With Quote
Old 10-18-2012, 12:48 PM   #2
joegr
My Ride: 2002 325i
It's not an airbag deployed light. It's an SRS fault light.
It sound like your explosive seat belt tensioner or the wiring to it has failed. There are some tests to do to figure out which it is.
Once you do correct the fault, you'll need a scan tool to turn the light back off.
joegr is offline   Reply With Quote
Old 10-18-2012, 02:26 PM   #3
haurelio
My Ride: 2001 bmw 325i
Its usually the belt tensioner or the seat occupancy sensor..try removing the yellow connector under the seat for a couple minutes, clean it if needed and reset the light..
