Sponsored by The Tire Rack
Old 10-18-2012, 10:42 PM   #1
always-there
My Ride: 2002 BMW 330I
Aftermarket wheels
http://m.voices.yahoo.com/how-wider-...g-3973758.html
For all of you thinking of replacing your old wheel/tire, combo please read !
Old 10-18-2012, 10:52 PM   #2
Gheybe
Gheybe's Avatar
My Ride: F80 M3
I'm not reading this shiit.
Gheybe is offline   Reply With Quote
Old 10-18-2012, 10:59 PM   #3
always-there
It affects the performance of your car including torque, transmission shift points etc.
Old 10-18-2012, 11:01 PM   #4
Gheybe
Gheybe's Avatar
My Ride: F80 M3
My solution: run the widest square set up one can.
Old 10-18-2012, 11:04 PM   #5
always-there
So you want to stay as close or the same tire height your car was designed to work with. I'll be gunning for 2 sets of m3 front wheels and a set of Michelin tires in the 225/45/18 size. It should be a good combo. I'm just tired if the style 68 wheels.
Old 10-18-2012, 11:06 PM   #6
always-there
So what's the widest wheel and tire you can run without rubbing? We can't get a taller tire, it'll affect the car. I love the torque I have now, wouldn't want to sacrifice it.
Old 10-19-2012, 12:38 AM   #7
El_Grantus
My Ride: 328Ci
Do you mean "tyred"?
El_Grantus is offline   Reply With Quote
Old 10-19-2012, 01:49 AM   #8
ImolaSix
My Ride: '02 330Ci M-sport
That's the wrong tire size for a non M. The sidewall should be a 40 not 45.
ImolaSix is offline   Reply With Quote
Old 10-19-2012, 01:59 AM   #9
MercForHire
My Ride: M235i 6MT
All I can say is my 195 wide winters tires suck major balls on wet ground. Even a left turn at normal speed would spin the tail out a bit.
Old 10-19-2012, 09:25 AM   #10
always-there
Nope, I mean "tired", lol??
Old 10-19-2012, 09:28 AM   #11
always-there
Imola, my stock tires 225/45/17. What I'm wanting to do is gain better traction and handling. So having a wider wheel and tire is a must, that is without rolling fenders and what not.
Old 10-19-2012, 08:04 PM   #12
always-there
I like it.
Old 10-20-2012, 12:55 PM   #13
fth001
My Ride: 325i, e36m3, s13
+1, if you want to keep the same tire height then a 225/45/17 would be roughly the same height as a 225/40/18. check this link http://www.miata.net/garage/tirecalc.html
fth001 is offline   Reply With Quote
