Sponsored by BimmerWorld
Old 10-19-2012, 01:54 AM   #1
Assimilator1
My Ride: E46 330d SE
E46 330d Meyle shocks any good?
So the Meyle wishbones & RCABs are reckoned to be pretty good, but has anyone used or know what Meyle shock absorbers are like?
I need some new front shocks for my 330d, Meyle ones are going for 50ea all in, (actually it looks like I can get a pair for 84! )
Or its Monroes for 60-70ea (Boge are too expensive @ ~192 the pair)
TIA
Assimilator1 is offline   Reply With Quote
Old 10-19-2012, 01:57 AM   #2
MercForHire
My Ride: M235i 6MT
i like meyle everything. they must make good socks as well.
Old 10-19-2012, 02:43 AM   #3
lucky_doggg7
My Ride: 2005 M3
Myle makes dampers? In any case, Bilstein dampers come with a lifetime warranty and Bilstein is a known Company for selling solid dampers. As for the type of Bilstein damper they make a HD or heavy duty damper that is just marginally stiffer than stock, and then they make a sport shock that is valved tighter (with a shorter piston length to work wth lowering springs) to provide more stability at higher cornering speeds; of course, this sport damper will transmit more road irregularities through the chassis. If a stiff ride is not agreeable, choose the HD dampers.
Old 10-20-2012, 02:08 PM   #4
Assimilator1
I don't want a stiffer ride, it's too stiff as it is
Unfortunately Bilstein shocks are 188 a pair vs 84 for Meyle!
Anyone else on Meyle?
