Sponsored by BimmerWorld
Old 10-19-2012, 06:49 PM   #1
titan05
My Ride: 2002 325i
02 325i A arm question
I found out today the ball joint has play in it on pass side but I have not took it off yet can i replace just the ball joint or replace the whole A arm and whats a good replacement without breaking the bank
titan05 is offline   Reply With Quote
Old 10-20-2012, 10:39 PM   #2
lucky_doggg7
My Ride: 2005 M3
The ball joint is not individually replaceable.
Look here:http://www.ecstuning.com/BMW-E46-325..._Arm/ES205222/
$140 bux, & a 4 yr warranty. Can't do better than that. Good luck.
Old 10-21-2012, 08:50 AM   #3
titan05
My Ride: 2002 325i
Old 10-21-2012, 08:55 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
The ball joint can't be replaced on an original Lemforder, but you might not have an original arm. Meyle HD arms have replaceable ball joints.
I considered those but ended up staying OE...as I almost always do.
There are cheaper CAs around (Febi/bilstein makes some), but IDK...in the long run, cheaper arms might end up costing more.
Oh, you can get meyle HDs with ca bushing mounted already, which makes replacement easier on you.
Usually, when removing CAB from CA, you'll mess up the CAB...in case you didn't know.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-21-2012, 04:39 PM   #5
titan05
My Ride: 2002 325i
Thanks again i went ahead and ordered control arms bushing and sway links from Bavarian Autosport
