Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 11-14-2012, 10:22 AM   #41
love2drive330CI
My Ride: 2001 330CI
I just got my BMW 1.4.0 last week.
Before you go in there to check/hopefully one of the wiser fanatics will chime in to confirm that P1500 code. I looked it up again and am getting conflicting information so I don't want to send you on wild goose chase.
I checked here:
http://www.my330i.com/odb2a.php
I would use the bmw scanner first to see what it tells you.
love2drive330CI is offline   Reply With Quote
Old 11-14-2012, 10:44 AM   #42
scarede46er
My Ride: 2001 BMW 325i ZSP
I got mine a couple of months ago. I keep it in the glove compartment along with a convertible tablet running Windows to diagnose any fault immediately.
Old 11-14-2012, 02:18 PM   #43
Weste46
My Ride: 2001 330ci
P1500 has been said to be many things.. the fuel pump relay is easy enough to swap with the horn, might as well! Thanks for the heads up though!
I'll be trying out my scanner again. I really hope it works! My circuit board was covered in black insulation, so it was a different model than what I saw online. Did you guys have this?
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 11-14-2012, 04:13 PM   #44
love2drive330CI
My Ride: 2001 330CI
I didn't have to pop mine open.
Old 11-14-2012, 05:55 PM   #45
Weste46
My Ride: 2001 330ci
Ahh. I followed the instructions online once it didn't work last time. I'll try fixing the connections!
Old 11-14-2012, 09:49 PM   #46
Weste46
My Ride: 2001 330ci
Wait.. do I need position 2 for the 1.4.0 scanner too?!
Edit: HOLY TITS I DO. THANK GOD IT FINALLY WORKS. all electronic modules would show up with position 1 so I never thought to check.. wow. Update with specific codes soon! 30 degrees out right now in flip flops, and I'm not even mad.
Old 11-14-2012, 10:49 PM   #47
love2drive330CI
My Ride: 2001 330CI
So what codes did you pull?
I won't tell you it was hot here today in Florida! !!!
Old 11-15-2012, 12:42 AM   #48
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
Please update us as soon as you can
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 11-15-2012, 04:06 PM   #49
Weste46
My Ride: 2001 330ci
Update: well, I got D3 [ 211 ] -- Idle speed control valve, mechanical fault, jammed open.
Sooo I guess the new one that I cleaned out thoroughly before installing was still messing up I have to assume? I bought it off eBay... maybe it wasn't really new.. its a Bosch, part number added up as well so it wasn't a clone. It was labelled as new from a high-rated seller.
After clearing the codes and driving home in limp mode, that's all i received, other than the "shadow" errors that would not clear, which were short circuits before catylist banks 1 and 2, and short circuit after catylist bank 2. I have no idea what these are.
I also had a lot of ABS errors, which none cleared. Steering angle offset -- CAN timeout instrument cluster -- DSC push button for over 10 seconds or error(?) -- CAN DME/DDE, engine torque not adjustable -- CAN timeout LWS.
Old 11-15-2012, 04:12 PM   #50
RayPooley
My Ride: 320i SE Coupe
Its all ferkin bollocks when you think about it. Its like putting a light bulb in charge of everything. Sensors don't make sense.
Old 11-15-2012, 04:31 PM   #51
Weste46
My Ride: 2001 330ci
Hoh-hah! Puns..
I guess its all in getting performance. Its a ton better when it works. When it doesn't though, it sucks.
Old 11-15-2012, 04:54 PM   #52
Weste46
My Ride: 2001 330ci
I guess I'll get a genuine BMW ICV and see if the new one was bad too.. I just can't believe that. Can someone run me through a detailed explanation of how the ICV is mounted onto the engine? I did not like how mine felt as I mounted it..
Old 11-15-2012, 04:56 PM   #53
Weste46
My Ride: 2001 330ci
Also, I cleared the errors AND EWS-DME adaptations on the last one, and came up with a new shadow code, a "crankshaft position sensor, no signal" error. It was only a shadow code though, so presumably nothing to worry about(?).
Old 11-15-2012, 05:21 PM   #54
03E40sick
When you installed the new one i suppose, was it moving or you pushed in good ? The valve that goes into the car has robe pushed very good, I am waiting on my new one should be here today or tomorrow I will keep you posted
Old 11-15-2012, 06:16 PM   #55
Weste46
My Ride: 2001 330ci
I pushed it in hard but not hard enough to feel anything solid.. it felt dangerous to push harder. I hoped the bolts would pull it in more. Maybe an air leak directly after the ICV is adding more air and the computer assumes its the ICV.
Old 11-15-2012, 11:39 PM   #56
03E40sick
That could be an issue as well, but when you push it in , u should feel that it is in , it should give you that click sound .. Mine came in today .. Should be replacing it tomorrow or Saturday
Old 11-16-2012, 03:04 AM   #57
Weste46
My Ride: 2001 330ci
Click? Mine felt like I was pushing into rubber.. I never really checked out the mount well.. how exactly does the ICV sit into the engine? In a rubber grommet?
Thanks, and yeah keep us updated!
Old 11-16-2012, 08:59 AM   #58
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Yup. There is a grey rubber grommet that the icv sits in
sent from my dahc-6900 using Bimmer App
Old 11-16-2012, 01:20 PM   #59
Weste46
My Ride: 2001 330ci
Okay well I'll most likely try to remount it tomorrow and see if that's the issue.. any other advice while I'm in there, anyone?
Old 11-16-2012, 01:53 PM   #60
03E40sick
Hmm .. Double check with cracks, or any leaks and make sure when you put the lower elbow to the throttle body, it's tight and on correctly bc for some reason the way it's designed it can slip easily which I hate very much, and check all the connections as well
