Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 11-16-2012, 03:50 PM   #61
Weste46
My Ride: 2001 330ci
Gotcha! All boots are new and beautiful and I cleaned all connections with MAF cleaner last time, but will tighten up the harness connections! At least it says mechanical, not shorting! I'll update tomorrow!
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 11-16-2012, 05:07 PM   #62
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
Okay that's great and that's what I am doing as well as soon as I get my hands on it I will let you know
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 11-16-2012, 09:19 PM   #63
03E40sick
One more thing I want to mention hat is I have an after market intake,just the filter everything el is there and by that I mean the throttle elbow and the plastic piece that connects to the other elbow which connects to the MAF then the MAF is connected directly to the filter .. Would this cause the problem in any chance ?
Old 11-16-2012, 11:40 PM   #64
Weste46
My Ride: 2001 330ci
That could throw lean codes, or MAF codes, but I don't believe its known to throw many ICV error codes. I have an Apexi Power intake mounted on mine as well, but with tubing and a heat shield.
Old 11-17-2012, 02:51 PM   #65
Weste46
My Ride: 2001 330ci
I sprayed starter fluid all around the ICV and TB with no movement in RPM at all. I'm doubting this theory.. I don't want to risk damaging these boots for the 4th time, tearing them out, if I don't think it'll change anything..
I'm hoping someone has another idea to motivate me to open it all back up again! :p
Old 11-17-2012, 04:29 PM   #66
03E40sick
I just replaced my ICV and the same **** happened again... I'm so sick of this .. Idk what els to do
Old 11-17-2012, 04:34 PM   #67
03E40sick
I am giving up guys :/
Old 11-17-2012, 04:55 PM   #68
Weste46
My Ride: 2001 330ci
Well hey, we're not alone.. check this out:
http://forum.e46fanatics.com/showthread.php?t=945802
Same thing.. different thread.
Old 11-17-2012, 09:37 PM   #69
03E40sick
I was reading that thread a while ago, nothing more than we already discussed
Old 11-21-2012, 08:24 PM   #70
Weste46
My Ride: 2001 330ci
After Thanksgiving I'll be back on it! Keep everyone posted!
Old 11-21-2012, 11:53 PM   #71
Weste46
My Ride: 2001 330ci
Does anyone else have a red oil light and yellow traction light flash incredibly briefly on shutdown? Its intermittent, and lasts less than a second.
Old 11-22-2012, 02:23 AM   #72
03E40sick
The red light for the oil might be the sensor going bad or the car needs oil or bad reading, but for traction no idea
Old 11-22-2012, 05:14 AM   #73
Dippinwandy
My Ride: 325i
Looks like no one has found a definite answer..
Dippinwandy is offline   Reply With Quote
Old 11-23-2012, 05:43 PM   #74
03E40sick
I know this is just not right
Old 11-24-2012, 12:11 AM   #75
Weste46
My Ride: 2001 330ci
Yeah for my lights, the red light means oil pressure sensor might be bad, but with the traction light I'm really not sure.. nobody seems to know that. I've literally never found anything on it except for a thread I found, which was made by my vehicle's previous owner. Never solved obviously. Haha.
Old 11-24-2012, 08:13 PM   #76
Weste46
My Ride: 2001 330ci
Okay, someone needs to fold and take it into a dealership soon if nobody can figure it out. Since I have both work and school and have no other means of transportation, I vote someone else to be our savior!
I'm not giving up, I love my car too much! Let's stay updated on any ideas on what it could be! Anyone try fuel pump relay yet? Mine was still unreachable after glove box removal...
Old 11-25-2012, 03:03 PM   #77
03E40sick
I agree with you, I haven't changed that either .. Lets keep in touch ... I might bring it in this tomorrow so I will let's guys know
Old 11-28-2012, 09:59 PM   #78
Weste46
My Ride: 2001 330ci
This Saturday I'll be having someone watch the live data from my 1.4.0 scanner to see if anything peculiar happens when limp mode engages..
Old 11-28-2012, 10:45 PM   #79
scarede46er
My Ride: 2001 BMW 325i ZSP
Really? If your car goes to limp mode each time, hasn't it thrown a code that you can read already without waiting for limp mode to kick in?
Old 11-29-2012, 05:37 AM   #80
RayPooley
My Ride: 320i SE Coupe
Pay attention to the cylinder adaptation values. These relate to how well the computer is managing to keep the air/fuel mixture close to the ideal 14.7:1 ratio. It uses the input from the MAF and O2 sensors to adjust the fuel supply to the cylinders. I have attached a useful document on adaptation. It may help in diagnosing which cylinders are faulting.
