Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 11-29-2012, 10:31 AM   #81
Weste46
My Ride: 2001 330ci
The only code I ever get is P1500. I already cleared all adaptations. Would this issue still be present?
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 11-29-2012, 10:32 AM   #82
Weste46
My Ride: 2001 330ci
Also, I thought the M54B30 was 10.6 to 1 ratio?
Old 11-29-2012, 10:43 AM   #83
RayPooley
My Ride: 320i SE Coupe
Take a look here. Mixed opinions though as to what a P1500 means.
http://forums.bimmerforums.com/forum....php?t=1187095
THis shows Idle Speed Control Valve Stuck Open. Maybe it just needs cleaning??
http://www.obd-codes.com/trouble_codes/bmw/
Old 11-29-2012, 11:07 AM   #84
WDE46
My Ride: '13 128i, '04 330Ci
Thats the compression ratio. That ratio is determined by this:
Volume of 1 cylinder at bottom dead center / Volume of 1 cylinder at top dead center
All cars try to run the same Fuel/Air ratio. That is just how the chemistry works. You need 14.7 parts air to completely combust 1 part of fuel. It varies with air quality though. This assumes air with a composition of 79% nitrogen and 21% oxygen.
Old 11-29-2012, 01:58 PM   #85
Dippinwandy
My Ride: 325i
someone brought up the hose from the icv to the intake. Would that be the grey one that sits inside the intake manifold ?
Dippinwandy is offline   Reply With Quote
Old 11-29-2012, 02:18 PM   #86
RayPooley
Check this out. Courtesy of Solidjake E46Fanatics
Old 11-29-2012, 04:22 PM   #87
Dippinwandy
My Ride: 325i
Yes i have done the procedure many times .. I used that same video..That wasnt my question though.
What is the hose from the icv to the intake?
Old 11-29-2012, 04:51 PM   #88
RayPooley
Don't know the hose you are talking about. Can you find it on here?
http://www.realoem.com/bmw/select.do
Old 11-29-2012, 08:37 PM   #89
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
You are talking about that the grey rubber piece that connects the ICV to the intake manifold .. It could thro the codes as well ...
http://my330i.com/odb2a.php
On that website the code p1500 sad that its the fuel pump relay.. Confusing
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 11-30-2012, 03:52 AM   #90
RayPooley
It is the idle control valve we are talking about when using ICV acronym isn't it? Just that there is no evidence of a grey tube on my ICV. So I don't know the tube in question.
Old 11-30-2012, 11:30 AM   #91
03E40sick
Yes that is what we are talking about, the grey tube is in the intake manifold when u take out your ICV look closely where the icv goes into, it's the grey tube
Old 12-01-2012, 05:52 AM   #92
Dippinwandy
My Ride: 325i
Did you happen to replace it when you replaced your icv?
Old 12-01-2012, 11:28 AM   #93
Weste46
My Ride: 2001 330ci
I could not get to my fuel pump relay, but a bad fuel pump relay is supposed to cause absolutely no power to the fuel pump, therefore the engine would not start at all. We would have stalling issues and etc.
Old 12-01-2012, 05:19 PM   #94
Weste46
My Ride: 2001 330ci
The picture is what popped up from the live data on my 1.4.0 scanner when in limp mode..
I didn't see anything about cylinders, maybe it doesn't have the technology for that..
Old 12-01-2012, 05:20 PM   #95
Weste46
My Ride: 2001 330ci
This is the full list of streaming data.
Old 12-01-2012, 05:23 PM   #96
scarede46er
My Ride: 2001 BMW 325i ZSP
Click on data group + button. That should give u more stuff. Plus you need to scan each module and double click on them to see the error. The ICV would be in DME.
Old 12-01-2012, 05:43 PM   #97
Weste46
My Ride: 2001 330ci
Ahh.. other buttons. Woops. I'll do that! I have been into the DME module, I'm trying to find other errors to see if anything else is happening momentarily but not showing up as errors on the DME.
Old 12-01-2012, 09:04 PM   #98
03E40sick
Anything to point to guys, this is frustrating lol
Old 12-02-2012, 10:56 AM   #99
Weste46
My Ride: 2001 330ci
So my steering angle sensor must be out. Has anyone heard of that causing limp mode?
I'm thinking the MIL status is just saying that I am in limp mode, because limp mode forces the engine to run rich, right? I need to run this again and see the other pages.. the problem is my computer dies in about 5 minutes so I can't keep running the test.. unless I go buy a new laptop battery, or a converter..
Old 12-02-2012, 01:36 PM   #100
03E40sick
Idk if that would cause the eml light to come on, but I know it causes the brake and traction control light to come both yellow of course bc it happened to be before, then I got an alignment and it went away
