Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 12-15-2012, 04:52 PM   #141
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
I replaced the intake to the stock one, drove about 28 miles then what do you know, the lights are on again
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 12-15-2012, 05:31 PM   #142
Dippinwandy
My Ride: 325i
That sucks man. What air filter did you use? I put my bmw performance intake and i havent had any problems in 2 days....
Dippinwandy is offline   Reply With Quote
Old 12-15-2012, 07:10 PM   #143
03E40sick
I put the stock intake back on , the problem is not as bad as before but still there :/
Old 12-16-2012, 12:08 AM   #144
Weste46
My Ride: 2001 330ci
You were getting a code other than P1500. Maybe its related?
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 12-16-2012, 03:00 PM   #145
03E40sick
Yes it is p1150 any ideas guys ?
Old 12-17-2012, 05:22 PM   #146
Weste46
My Ride: 2001 330ci
I can't find any BMW info on that code.. scan them again, see if that's really the code?
Old 12-18-2012, 11:01 AM   #147
03E40sick
Okay I will double check
Old 12-30-2012, 03:00 PM   #148
Dippinwandy
My Ride: 325i
Any updates on this?
I havent seen my codes for over 2 weeks
Old 12-30-2012, 03:08 PM   #149
Weste46
My Ride: 2001 330ci
I haven't seen any codes since my fix either! Just did my engine mounts, about to do transmission mounts too. Got a whole list of maintenance I need to catch up on haha!
Old 12-30-2012, 03:58 PM   #150
Dippinwandy
My Ride: 325i
Sounds good bro. I have a couple of things to catch up on myself !
Old 01-04-2013, 01:15 AM   #151
Dippinwandy
My Ride: 325i
Annnnnnd they're back.....
Old 01-04-2013, 02:19 AM   #152
Weste46
My Ride: 2001 330ci
Oh Jesus... great. I bet it'll happen to me too, then. That's bad luck. I just got rear-ended yesterday too. Only bumper cover damage, but annoying to deal with.
Hm, what to attack next?
Old 01-09-2013, 03:34 PM   #153
Weste46
My Ride: 2001 330ci
I'll update this with a thought.. maybe buy a single ignition coil and switch each out, one by one, and run the engine in between. I've heard of people getting limp mode from ignition coils, and I've also heard of people (many people) having bad ignition coils on our e46's that don't throw codes.
Just a thought. My codes still have not returned.
Old 01-17-2013, 02:15 PM   #154
Dippinwandy
My Ride: 325i
I might just get new ignition coils.. Its about that time....
Old 01-17-2013, 09:45 PM   #155
Weste46
My Ride: 2001 330ci
Might as well try it. Keep it updated. It sucks that you still have this going on.. just to be sure, you might as well clean out and tighten up both VANOS solenoid connections, and your MAF connection. Use some CRC MAF cleaner for all 3 and tighten them up by bending the actual 'inside' metal tab inward, so they make better contact. I accidentally bent the outsides of them in the first time and loosened them.. there are thin tabs inside the metal piece..
anyway, do that, it's an easy job. might as well?
Old 02-08-2013, 04:30 AM   #156
Dippinwandy
My Ride: 325i
It's still happening on the daily.
Old 02-09-2013, 11:46 AM   #157
Weste46
My Ride: 2001 330ci
Ever get new coils?
Old 02-09-2013, 02:45 PM   #158
Dippinwandy
My Ride: 325i
Ever get new coils?
No i didnt but the previous owner did because they are the performance ones..
Old 02-10-2013, 07:37 PM   #159
Weste46
My Ride: 2001 330ci
Ah... man I would just bring it in... that sucks. Mine is gone..
Old 02-13-2013, 10:11 PM   #160
Dippinwandy
My Ride: 325i
So a member on here showed me a link to a thread were a guy was having this same problem with the icv and took it to his mechanic. His mechanic figured out that one of the wires going to the icv was dead. I think this might be many of our problems.
I just do not know which wire it was or what the correct voltage should be or which is the ground and positive... Does any one here know by any chance?
