Old 10-20-2012, 12:16 AM   #1
eRa11
My Ride: 325i
Exclamation Weird Noise, need help!
Hello need help identifying a noise my car started making. its an 04 325i, around 93k miles on it. The car makes those high noises when started after being off for hours, usually mornings or after work. Also i started hearing the noises when the weather started to get cooler, not sure if it has any kind of relation. The noise persists when slightly stepping on the gas sometimes it even gets higher it goes away at about 4k rpm. This goes on for a couple of minutes then goes away. Figure i would post here first hopefully get suggestions as to what the problem may be before taking it to a mechanic and start throwing money. many thanks in advance.
eRa11 is offline   Reply With Quote
Old 10-20-2012, 03:04 AM   #2
lucky_doggg7
My Ride: 2005 M3
If I were to shoot from the hip, i's say it's a pulley bearing that's failed.
Old 10-20-2012, 04:31 AM   #3
BimmItUp
My Ride: 01' 330i
Got 100% same noise!! Still tracking it down. So far I have narrowed it either alternator bearing/pulley or idler pulley. If its not that then I've read the tensioners can go bad as well.
BimmItUp is offline   Reply With Quote
Old 10-20-2012, 06:33 PM   #4
jjamal99
My Ride: 2006 BMW ZHP
I have the same problem as well. I changed both of my belts to no avail. I'm gonna try the belt tensioner next and maybe alternator pulley.
jjamal99 is offline   Reply With Quote
