The Showroom
Old 10-20-2012, 03:23 PM   #1
BrianSpilner
My Ride: Max PSI Stage 2
Custom Mid-Pipes by Fluid MotorUnion. Evosport + FMU + Cutout + Agency Power V1
[SCROLL DOWN FOR PICTURES AND VIDEOS]
Over the years I have been through quite a few different exhaust setups and none of them really brought out that super aggressive tone I was looking for. I had OEM Section 1 with AR25 Resonators, Super Sprint Section 1 with racing cats, Super Sprint Section 2 with custom 2.5" dump valve, Active Autowerke Generation 3 exhaust, Active Autowerke Generation 4 exhaust, Gruppe M Exhaust, Rogue Engineering El Diablo Track Edition Exhaust; and I think that's it.
Finally, I completed an exhaust setup that I think sounds THE BEST! I've heard a bunch of exhaust setups on various supercharged M3's and none of them had that sound that "means business." They all sounded puny with a ton of rasp. I wanted to get rid of the rasp, mainly, and have a sound that is distinct to my car. -I think the 3.5" mid-pipe was the trick.
My FINAL exhaust setup is as follows:
-Evosport Headers
-Fluid MotorUnion Custom 3.5" SINGLE Pipe Section 1 & Section 2
--No Cats
--No Resonators
--QTP 3.5" Exhaust Cutout Dump Valve (Controller built-in to ash tray)
-Agency Power V1 Exhaust
www.fluidmotorunion.com
EDIT about DYNOS:
I did not complete any dynos before and after, unfortunately, just after. I didn't have time to do so since we were in a time crunch to complete the parts before an upcoming car show. My car really woke up after, though. It felt like the car just 'flowed' better or came alive. You don't gain anything from the valve (per-say), it's just there for the "Cool" factor. With it open, you lose a lot of low end power, but gain top end power (you can feel it). Again, it's just there for the cool factor. The sound is super aggressive and sounds better than ANY other exhaust system imho. Most M3's sound like sh!t because they rattle like a tin can, and even the ones with the rasp terminators still don't sound mean enough. I think it's the 2.5"-2.75" they all run and the fact that the mid-pipes are broken down into 2 different sections; one using 1 pipe and the other using 2 pipes. 1 3.5" pipe flows more air than 1 2.5" pipe dumping into 2 2.5" pipes or vice versa. If that makes sense.
I have a friend with a similar exhaust setup as mine, but he is NA and running a single 3" from headers to exhaust. He has a couple threads of dynos before and after via Evolve tune. I would assume that with a blower or turbo, the gains would be even more drastic.
Here is the build thread:
http://www.m3forum.net/m3forum/showthread.php?t=404652
Here is the the thread with dyno numbers: http://www.m3forum.net/m3forum/showthread.php?t=416011
Those should give you a good idea on what to expect and then some, especially if you're boosted.
Here are pictures of the build (Photos by Andrew Krok @ Fluid MotorUnion and John Bieronski):
Videos of Exhaust:
Idle Rev:
Cutout Closed, Rev + Acceleration:
Cutout Open, Rev + Acceleration:
I'll update the thread with flyby's when I get a chance to do so.
Follow My Builds: Max PSI Stage 2 E46 M3 Turbo Build | 1972 2002 Restomod Build
2004 BMW E46 ///M3 | Maximum PSI Stage 2 Turbo | SMGII | Non-Catted | 711rwhp | 578rwtq
BrianSpilner is offline   Reply With Quote
Old 10-20-2012, 03:30 PM   #2
BrianSpilner
My old exhaust setup(s) videos (Couldn't find the AA or RE El Diablo Videos, sorry):
-Evosport Headers
-Stock Section 1 with AR20 Resonators
-Super Sprint Section 2 with 2.5" Dump Valve
-Gruppe Titanium Exhaust
Old 10-20-2012, 03:33 PM   #3
Snik
Snik's Avatar
My Ride: IR M3 Vert.
wow...
Do you ride a sportbike?
Old 10-20-2012, 04:22 PM   #4
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Sounds great Kris!
Old 10-20-2012, 04:25 PM   #5
BrianSpilner
Originally Posted by MarcusLSB View Post
Sounds great Kris!
Thanks Marcus, I appreciate it! Can't wait for you to finish one of your builds
Old 10-20-2012, 04:44 PM   #6
j_block
My Ride: 2003 325i
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 10-20-2012, 05:53 PM   #7
robolop
My Ride: 323ci
PORN
robolop is offline   Reply With Quote
Old 10-20-2012, 06:24 PM   #8
n3985
My Ride: E92 soon?
IU car sounds great
n3985 is offline   Reply With Quote
Old 10-20-2012, 06:31 PM   #9
flipm3
My Ride: 02 M3, 97 328i
Send a message via AIM to flipm3
Wow...Incredible.
The tone of the exhaust really surprises me especially since you don't have a single cat or resonator.
2002 E46 M3 6MT | Jet Black . Black Nappa | My Build Thread
Evolve Automotive CF Airbox & AlphaN . Supersprint V1 Stepped Headers & V1 SPipe
flipm3 is offline   Reply With Quote
Old 10-20-2012, 07:17 PM   #10
BrianSpilner
Originally Posted by flipm3 View Post
Wow...Incredible.
Yea, I think it really has to do with the SINGLE 3.5" piping. Probably a mixture of the diameter of the piping and the fact that it's only one pipe rather than 2 pipes (S-Pipe) running into 1 pipe (X-Pipe) like the OEM or any other mainstream aftermarket product.
Old 10-20-2012, 10:04 PM   #11
Snik
Snik's Avatar
So is it louder with a single 3.5" pipe. I know it founds super sexy. Butvusbit louder also?
And what does it do to the power and torque vs the dual pipe setup?
Old 10-20-2012, 10:09 PM   #12
BrianSpilner
Yes, it is "louder", but there's no rasp or drone (just a little) inside the cabin. To see the power gains of a 3.5" pipe, you'd need to be supercharged or turboed because you'll lose all the back pressure necessary for a NA motor/setup; especially with no cats or resonators.
I believe 3" is the maximum recommended diameter for a NA exhaust setup. One pipe from headers to exhaust is better than 2 pipes dumping into 1 pipe in terms of exhaust flow and power.
I wish I did some dyno runs before and after this setup to show the difference.
Here is a thread with pictures and a video of my buddy's similar exhaust setup, but he's NA running a 3" single mid-pipe; complete with dyno charts:
http://www.m3forum.net/m3forum/showt...ht=fmu+exhaust
Old 10-20-2012, 10:41 PM   #13
Snik
Snik's Avatar
fukin legit bro...
Old 10-21-2012, 01:09 AM   #14
Tchleung
My Ride: 02 M3
This sounds great man.
I'd be curious to see how it sounds with the V2 muffler or something similar to that style such as Status Gruppe Tuning etc.
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 10-21-2012, 01:13 AM   #15
BrianSpilner
I REALLY wanted the V1 when I was searching for it a few months ago. I had the same "tubular" style exhaust when I had the Rogue Engineering El Diablo Track Edition Exhaust; it had a lot of drone.
Not to mention HPF did an exhaust dyno test to see which flows the best and the Agency Power V1 was #1 followed by the RE El Diablo I had before.
I just feel that the Super Sprint Race Design of the Agency Power V1 has a unique sound, considering all the rest of the exhausts have the same "tubular" design as described above.
Old 10-21-2012, 06:51 AM   #16
2006BMWM3ZCP
My Ride: M3 ZCP, E55 AMG
used to have the AP v1 exhaust. best exhaust ive ever owned.
2006BMWM3ZCP is offline   Reply With Quote
Old 10-21-2012, 08:56 AM   #17
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
i like it with the cut out closed. always thought bmws should have a deeper tone. With it open, it sounds way too obnoxious to deal with everyday. How about in cabin sound?
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 10-21-2012, 11:47 AM   #18
BrianSpilner
100% Agree!
Old 10-21-2012, 12:21 PM   #19
domcreates
Banned User
My Ride: Jet Black 1999 323i
awesome, sounds a lot better than the one video I watched of one of your old set ups
domcreates is offline   Reply With Quote
Old 10-21-2012, 12:30 PM   #20
BrianSpilner
To be honest, the cutout option is just for the "cool" factor of controlling the already amazing exhaust tone. In person it's comparable to a crotchrocket with a slip-on exhaust. I NEVER drive around town with it open, because it's just super loud inside and outside the cabin. I mainly open it up at car meets, shows, and to people that pull up next to me that 'believe' they have a chance
I'll have to make some videos and update this thread with videos of it open and closed so you can see what it kind of sounds like. The Agency Power V1 exhaust has little drone as compared to the RE El Diablo I had before.
