Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#1 |
Squeeling noise- VIDEO
I've had this noise for a couple weeks.
I've been busy with work and I didn't have time to work on it myself so I dropped it at a supposedly reputable shop (Cambridge Auto in San Antonio). They said it was the ac pulley tensioner and replaced it. Did absolutely nothing to fix this noise. Any thoughts on what else I should look at? |
#2 |
The belts look good. Almost look new.
#3 |
I could be wrong but if memory serves me correct this is the noise my bad tensioner pulleys made.
#4 |
Software/Electronics/Custom
My car does the same thing and I've replaced all tensioners and pulleys except for crankshaft pulley, power steering. Also being that the alternator and AC compressor run on the belt do those units count too? I'm also assuming you can't just replace the pulley on those parts.
Sent from my SPH-L710 using Bimmer App
Bay area, Modesto, Stockton. my Services: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics. (DIY: RFID push button starting system coming soon SUMMER 2013. No more locked doors)DIY AK90 A walk through on coding your mcu and transponders EWS3 (ak90 review) |
#5 |
I'm suspecting its my power steering pump and its pulley. I've been dealing with reservoir leaking for quite some time. I should be getting parts to replace today from pelican parts
