Old 10-22-2012, 01:02 PM   #1
kobefanatic2289
Banned User
My Ride: 2002 330i Silver
2002 BMW 330i Engine rattle/ticking [Video included]
Hey fanatics!
Long time lurker and reader, but I haven't posted much.
I'm having an engine sound issue with my beloved 330i.
Long story short, after initial start-up there is a persistent rattle or clicking sound coming from the engine. It appears to come on once the car has sufficiently warmed up.
I've had the car for a little over a year now and have been trying to diagnose the problem as best as I could. I'm not sure what kind of oil the previous owner has been putting in, but I just replaced the VANOS seals and rattle rings (kit from BeisanSystems) and at the same time I did an oil change. I put Royal Purple 5W-30 (please don't flame me for not using BMW certified LL-01 oil ;P) into the engine, as I had a bunch of it laying around from before so I figured it would be okay to use in the bimmer. End result is still the same though. I have also tried unplugging the DISA unit as some posters have suggested, but that didn't appear to help.
I've uploaded a video onto YouTube so you guys can get a better idea of the issue:
I'd greatly appreciate any input and help from you guys, thanks!
kobefanatic2289 is offline   Reply With Quote
Old 10-22-2012, 04:14 PM   #2
TheJonRoss
My Ride: 2002 325xi, 2005 X5
Wait 'til Mango gets here
-Jon
BMWCCA# 473325
Join the Experience
TheJonRoss is offline   Reply With Quote
Old 02-21-2013, 10:11 AM   #3
kobefanatic2289
Banned User
Bump!
Old 02-21-2013, 11:10 AM   #4
wildirish317
My Ride: 2004 325Ci vert
Still have the problem since October? I suggest you buy a mechanics stethescope and try to pin point the source of the noise. My first guess would be a lifter or injector, but it could be a number of things. Does it go away when you rev the engine?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-21-2013, 11:14 AM   #5
kobefanatic2289
Banned User
Thanks for the suggestion; I will take it to my brothers shop and see if he can find the location of the noise as he probably has a stethoscope.
Ya, it goes away once you rev the engine and then comes back during idle.
Old 03-28-2014, 01:18 PM   #6
Sobhanarif
My Ride: E46 325
Hi there, I'm new to the forum and came across this post. I have the exact same noise (I can't find a video that matches the noise as perfectly as the one above does), and was wandering if you found out what the noise was and how to fix it. I'm hoping someone here knows what it is and how to fix it. Thanks in advance
Sobhanarif is offline   Reply With Quote
Old 06-01-2014, 11:37 AM   #7
/\/\III
My Ride: /\/\ III
Can we start posting the fix so that we wouldn't have to create a new thread with the same problem...i have the same problem and still can't find the problem/solution.
/\/\III is offline   Reply With Quote
Old 06-01-2014, 11:56 AM   #8
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Aside from the very faint lifter and possibly fuel injector tick, that lower pitch "tick" actually sounds like a rod knock. Not much solution for that besides a comprehensive engine rebuild.
Cavi Mike is offline   Reply With Quote
Old 06-01-2014, 12:00 PM   #9
VishTheFish
My Ride: Ex M54B30 ZHP
^ +1
The higher pitched ticking is very common, nothing really to worry about. But that lower, slower ticking does sound like rod knock like cavi mike said.
VishTheFish is offline   Reply With Quote
2000, 2001, clicking, knocking, m54
