Old 10-22-2012, 01:03 PM   #1
Rollk1
My Ride: 2001 330i
Prefacelift Xenon Bulb Replacement
Is there a demo on how to replace the xenons on a prefacelifted model? I can only find videos of newer models that have a case assembly that makes it seems pretty easy, but it looks like I have to remove the actual headlight to access my bulbs. Any insight?
Rollk1 is offline   Reply With Quote
Old 10-22-2012, 01:42 PM   #2
trj
My Ride: 325Ci
No, you dont have to remove the headlights if you are replacing the bulbs.
Just remove the rubber boot, then the bulb holder, then the bulb.
Pre-facelift and facelift for sedans are same except for the shape of the head lights.
Old 10-22-2012, 01:54 PM   #3
Rollk1
My Ride: 2001 330i
My assembly box is covered by the front brace bar though... it looks like you either need to remove it or have very tiny hands. I'll try to snap a photo to show
Old 10-22-2012, 02:00 PM   #4
trj
My Ride: 325Ci
Do you have stock headlights or aftermarket?
Even if you have to remove the headlights, it should be remove the trim below the headlight, remove the turn signal light(one Screw) and then 4 screws on the headlight housing and it will slide out.
Old 10-22-2012, 02:18 PM   #5
Rollk1
My Ride: 2001 330i
Nevermind, I figured it out. I have round rubber boots (a pain to put back on, btw) and was originally looking for a plastic box like on the newer models
Old 10-22-2012, 02:23 PM   #6
trj
My Ride: 325Ci
Yup the rubber boots threw you off.
I believe all e46 have the rubber boots on the headlights.
May be the e90s and f30s have plastic cover.
Old 10-22-2012, 02:41 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Simple was is also to take a 8mm socket and take out the two bolts on the back of the headlight, then the entire assembly will slide forward giving a lot more space.
