Old 10-22-2012, 03:03 PM   #1
01E46POWER
My Ride: 2001 BMW 325i
Airbag Light??????
So I just changed the sensor inthe passenger side airbag and the seat pressure sensor. These were the only bad sensors having to do with the airbag, yet the stupid light will not go off. Any ideas on how to get this light to go off?
Thanks in advance
01E46POWER is offline   Reply With Quote
Old 10-22-2012, 03:11 PM   #2
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
need a reset tool
http://www.bimmertools.com/Peake-Res...r-BMW-s/52.htm
or shop
but, what about years after 03? why no tools listed for say, an 04?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 10-22-2012, 03:22 PM   #3
01E46POWER
Awesome!!! Thanks for the tip. Quick question, it looks like these are just airbag tools. Are there any tools that are for all codes?
Old 10-22-2012, 03:23 PM   #4
HiHoBrian
My Ride: 05 M3
Pa soft 1.40
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 10-22-2012, 03:25 PM   #5
vicariously13
My Ride: 2004 330ci
Yes there are but for some strange reason, the one that resets airbags is its own special tool. This sounds like sarcasm but I can assure you, I'm being honest. I don't understand the need for a separate device for airbags but that's the way it goes. Check BavAuto.com. They have several different code readers available on their site and their customer service is great. I've been a customer for 8 years. No complaints.
No real mods... just loads of maintenance
vicariously13 is offline   Reply With Quote
Old 10-22-2012, 04:11 PM   #6
wasp9166
http://www.bimmertools.com/Peake-Res...r-BMW-s/51.htm
best money ever spent on my bmw
Old 10-23-2012, 05:09 PM   #7
madunix
My Ride: Silver 01' BMW 325ci
Originally Posted by wasp9166 View Post
whats so special about it? i use the torque app from the android market. does this scan tool give you more details about the code? for example, if i have an 02 sensor code, it'll tell me which sensor it is rather than figuring out whether its ank 1 sensor 1,2 or bank 2 etc..
madunix is offline   Reply With Quote
Old 10-23-2012, 07:08 PM   #8
wasp9166
you use your phone to read your codes?
enlighten me
i bought the peake years ago, there may very well be new options now, but for the moment, still the best money i've spent
Old 10-23-2012, 07:10 PM   #9
Zell
Zell's Avatar
My Ride: so turbo wow
Thanks in advance
Hey man, since you've done this swap and live in my area, would you mind helping me change my pressure sensor some time? Mine is slowly dying. Did you have any trouble taking the seat apart?
Old 10-23-2012, 07:33 PM   #10
madunix
enlighten me
https://play.google.com/store/apps/d...bC50b3JxdWUiXQ..
read the entire description.. where in ny are you?
Old 10-23-2012, 08:07 PM   #11
wasp9166
unbelievable
near poughkeepsie
Old 10-23-2012, 08:12 PM   #12
jfoj
My Ride: 330CiC, M5, X5, E93
The Torque app actually speaks to you!!
It announces when the car is up to temperature and it will also read out the codes and descriptions!!
The Torque Pro app and the ELM327 ODB Bluetooth adapter together are about $25!! Best $25 scan tool going.
Old 10-24-2012, 01:07 PM   #13
01E46POWER
Zell, I would let you know that getting to the actual sensor is a massive pain. Well first, is your set automatic or manual? Either way, I would recommend a bypass rather than a complete change. The leather has to come off and the cushion replaced. A bypass is cheaper, quicker, and easier.
Old 10-24-2012, 01:19 PM   #14
wasp9166
wadaya mean, ya gota drive with the phone plugged in or just let it idle til up to temp?
