Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
Poor lighting
Can or has anyone on here changed there projector xenon lights out and went with halogen instead. Im looking at removing the whole assembly and going with a halogen assembly and was wonding if any wiring has to be changed. This is on a 2003 325i
thanks for any info. |
#2 |
Past Site Sponsor
I would start changing your bulbs out? Checking for burned projector bowls? There's no way you would get a benefit going from OE Xenon to aftermarket halogen.
#3 |
#4 |
Mod
Bad move. Can you take a pic of your lighting at night?
What color are the bulbs emitting? Are they leveled properly? Do you have AL or ZKW lights?
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 Pics from post 505 on! ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#5 |
the lights are factory 4300k phillips d2s 35w. i just changed them to a aftermarket 6000k d2s 35w bulb but could not tell any difference so i put the original bulbs back in. the lighting is very dim on the car,is there any way to check the ballast?
#6 | |
If you don't mind getting your hands dirty you can retrofit some AL projectors in there and it will be much, much better. It requires a pair of AL projectors (~$100/pr on ebay), a pair of bixenon solenoid control circuits ($16/pr from here), disassembly, cutting up and drilling of your housings. Here is a how-to: http://www.zhpmafia.com/forums/showt...r-Retrofit-DIY Last edited by Wh33lhop; 10-25-2012 at 02:19 PM. |
