Sponsored by BimmerWorld
Old 10-23-2012, 08:02 AM   #1
uninc4709
My Ride: 2002 BMW 325i 5spd
what else?
I am replacing my struts and am curious what other miscellaneous items I should consider ordering while I have the car apart. Here is what I have ordered.
thanks
^^ more than likely a useless post
uninc4709 is offline   Reply With Quote
Old 10-26-2012, 12:59 AM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
you might need sway bar end links for either front or rear. you might find them to be quite worn or maybe even broken. 2 bmw's suspension work i did, both had the front right end link broken at the ball joint.
i also recommend the reinforcement plate for the rear shock mount. it's not totally needed since your new setup is stock and not overly stiff. but it's cheap and never a bad idea. search "z3 rsm reinforcement plate"
other than that you should be good.
