Old 10-23-2012, 02:03 PM   #1
ebarry
My Ride: 2002 330ci
New to Forum, code p0174
Got code p0174 found a vacuum line broken fixed it and it is still there. Car runs for about 5 min. then runs rough then stalls. I had to have it towed to my house didnt want to drive it. Could it be pre-cat sensors 146,000 miles I dont think they were ever changed
ebarry is offline   Reply With Quote
Old 10-23-2012, 02:15 PM   #2
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
vacuum leak - cheak the intake piping - often cracked
/_________\
O==[][]==O
Old 10-23-2012, 02:22 PM   #3
ebarry
My Ride: 2002 330ci
I checked didnt find anything, cleaned MAS, getting ready to check DISA valve, if anyone has any input please help before I tear the whole car apart
Old 10-23-2012, 08:22 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the first link below in my signature.
Probably will give you all the info you need to know.
One common problem that is hard to find is the CCV lower oil return hose that connects to the dipstick.
Old 10-24-2012, 10:43 AM   #5
ebarry
My Ride: 2002 330ci
Thanks I did read it the other day, I read alot that the car runs rough but not stalling, I can drive mine for a few minutes then it starts running rough then stalls. I checked the disa valve and it is shot could this be the reason?
Old 10-24-2012, 10:52 AM   #6
My Ride: Lexus
You won't find anything. A tear in the vacuum system or weak link in the fuel delivery system can cause these codes. My honest and genuine suggestion is to see sig, do it all.
Old 10-24-2012, 10:56 AM   #7
GSherbs
My Ride: 2002 330 xi
It is likely one of several reasons. If its toast, replace it and move on to the next possible culprit.
GSherbs is offline   Reply With Quote
Old 10-24-2012, 11:13 AM   #8
ebarry
My Ride: 2002 330ci
that seems to be the way to go just trying to keep costs down, I forgot to mention that I also got a p0444 code to start the whole thing. I went to autozone to see why the check engine light was on, they got 2 codes and cleared them and forgot what one of them was. the one they told me was p0444 and i guess the one they forgot was the p0174 because when i got stuck on the side of the road on the way to get the code checked again the code was the p0174
