Old 10-23-2012, 08:48 PM   #1
ecfrankyboy
My Ride: 325ci 2005
Is transmission fluid lasts forever ?
Hi,
Just a quick question. I've got a 325ci 2005 with a manual transmission. I'm at 138 000 km and am wondering if I should change the transmission and diff fluid. The dealer says it should last forever, but I'm skeptical.
I had a civic before and blew the transmission bearings around 160 000 km.
What do you guys think ?
Thanks for your help.
ecfrankyboy is offline   Reply With Quote
Old 10-23-2012, 08:51 PM   #2
adaseb
My Ride: 2002 BMW 320i
no.
adaseb is offline   Reply With Quote
Old 10-23-2012, 08:52 PM   #3
straight_beamin
My Ride: 2000 bmw 323i
Change it!!
straight_beamin is offline   Reply With Quote
Old 10-23-2012, 08:57 PM   #4
ecfrankyboy
My Ride: 325ci 2005
OOkkay. That confirms what I thought.
They're idiots.
Thank you people.
Old 10-23-2012, 09:07 PM   #5
jfoj
My Ride: '06 330CiC, '03 M5
Manufacturer says the fluid is lifetime. If you never change your fluid, it will last exactly the lifetime of your trans or diff!!
You decide if you would like to possibly extend the life of your driveline components.
Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619
Lower hose fan switch O-ring - BMW #13621743299
Old 10-23-2012, 09:55 PM   #6
SHOoff11
My Ride: 2006 Honda Civic Si
I have an automatic with 136k on it, I'm guessing it's too late to change the fluid now, because I heard if I do it will speed up the tranny failing on me. Is this true or should I go ahead and change it?
Originally Posted by SPDSKTR
You drive a BMW. That means you make $600,000 a year and date supermodels without pointy elbows or hairy arms. Need I say more?
2006 Honda Civic Si Coupe Nighthawk Black Pearl/Black
1995 Silver Frost/Gray Taurus SHO (sold)
1999 BMW 328i Sedan Alpine White/Sand (sold)
SHOoff11 is offline   Reply With Quote
Old 10-23-2012, 10:01 PM   #7
Stinger9
My Ride: '04 330Ci
Originally Posted by ecfrankyboy View Post
Hi,
Dealers give moron answers to questions like this.
I'd change the fluid if it was my car and had high miles on the trans. Even 136K miles!
But what does a guy who owns a manual know?
Old 10-24-2012, 07:02 AM   #8
jfoj
Change the fluid, as long as you use the appropriate fluid you cannot hurt anything. You will also get an idea of what shape the transmission is in once you have the pan down. It is a myth that changing the fluid will cause problems. Fluid oxidizes, breaks down, gets dirty and looses it friction coefficient over time.
Again, your transmission will last exactly as long as the fluid if you never change it. This may be 60k mile, this may be 160k miles??? You decide.
Old 10-24-2012, 08:10 AM   #9
wasp9166
ima touching member
wasp9166's Avatar
Location: tree fort in big oak on corner somewhere in ny
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
http://forum.e46fanatics.com/showpos...16&postcount=1
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
Originally Posted by vilseck21 View Post
Girl STOLE car because cvntwagon
wasp9166 is offline   Reply With Quote
Old 10-24-2012, 08:19 AM   #10
limpiabota809
My Ride: 330 XI
^ double thread? I always heard that if you change the fluid it will go bad sooner but I'm going to change it either way along with differential fluid after brakes and tune up for the winter
limpiabota809 is online now   Reply With Quote
Old 10-24-2012, 08:25 AM   #11
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.03809 mu
...and figure out what fluids to use, make sure you either use OE or read enough fluids threads that you actually feel bloated.
Change your fluids but don't drink any of them. Also, good time for other things too, you know...like maybe fuel filter, coolant flush, etc.
This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe."
The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax
Old 10-24-2012, 08:35 AM   #12
limpiabota809
My Ride: 330 XI
Oh jea coolant overhaul was completed last week...doing inspection 2 so fuel filter is definitely in there, oem fluid is definitely the way to go no doubt about that...but what happens if I get thirsty? Still don't drink the fluid?
Old 10-24-2012, 08:47 AM   #13
Wolrab
Registered Gadfly
Wolrab's Avatar
My Ride: 330Ci MT, 545i SMG
Send a message via Skype™ to Wolrab
There's an argument against changing the fluid in a high-mileage auto that has never had a fluid change - that you might disturb sludge that otherwise would stay put and not do any harm. Personally, I don't buy that, but you should be aware that not everyone has the same opinion.
On the manual and diff, there's no credible argument against changing it, other than what brainwashed dealers say about lifetime fill. Change it. Opinions on the interval vary from 30k to 50k miles.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 10-24-2012, 09:15 AM   #14
Stinger9
My Ride: '04 330Ci
++1 on this
When I did mine at 32K they were very good looking. Haven't done my trans since then, and not sweating it. But on my list.
Old 10-24-2012, 10:54 AM   #15
Platinum Plus Quality
My Ride: M54B30
I'm going to repeat myself again.
Replace all fluids in all parts in all vehicles--period! No exceptions.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 10-24-2012, 01:27 PM   #16
wasp9166
ima touching member
wasp9166's Avatar
changing fluid will make it not last as long huh.........................do you realize the logic or lack of , of this statement?
your engine wont last as long if you change the oil either, so don't do it
seriously, change it, do not flush it, flushing is the problem, not draining and refilling.................altho i'm not sure why you'd need to flush a manual anyway
just for anyone reading
Old 10-24-2012, 01:31 PM   #17
Wibbles
My Ride: 01 325i
So lets take this thread on a quick turn
On a Manual , would you use OEM BMW Maunal Tranny fluid, or something else? Again I'm mainly just wondering if it has to be to a certian spec like the oil... SO sorry ahead of time if this goes into a giant flame war on Tranny Oil, im just wondering I'm doing a diffrental fluid change and might as well do the tranny because I don't know if it was ever done (probably was just don't know when).
Wibbles is offline   Reply With Quote
Old 10-24-2012, 01:37 PM   #18
rcsummers
Mister TechnoMeister
rcsummers's Avatar
My Ride: M3
Flush it, I do mine every 30k or 3 years.
"RICH"
EURO.TECHNIKS
My Build Thread
rcsummers is offline   Reply With Quote
Old 10-24-2012, 02:19 PM   #19
My Ride: M54B30
I use Redline D4 ATF. Some people use Pentosin, some use Genuine, some use Redline MTL. All are fine
Old 10-24-2012, 03:26 PM   #20
wasp9166
ima touching member
wasp9166's Avatar
there is no reason to flush any transmission, particles, sludge, metal fragments etc get into places they shouldn't and cause wear where they wouldn't have otherwise , let the fluid and things break down on their own , change the fluid for newer fluid properties
there is a filter on an engine, so you don't need to flush, there is a filter on an auto, so you don't need to flush...............both of these have filters for a reason
there is no, and has never been a filter on a manual trans or a differential
for a reason
it is meant to be drained and refilled ...and that's it
