Old 10-24-2012, 10:03 AM   #1
cimca4120
My Ride: E46 (325xi)
brakes DSC and ABS ligths on
Hi all, I own an 325xi ī03 and i have a part replace on the front end of the car yesterday dont know the name in english (mulata o brazo), Havent take the car to alignmet but dont know it that whatīs causing the problem.
have some one had the same Issue? can i get some help plzzzzzz
cimca4120 is offline   Reply With Quote
Old 10-24-2012, 10:33 AM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Control arms? You may have knocked some speed sensor loose or simply need an alignment. Read the codes and tell us what the computer says.
Old 10-24-2012, 10:41 AM   #3
DHK
My Ride: 2002 BMW 325Ci
Most often and especially when not accompanies by other more noticeable symptoms this is caused by wheel speed sensors.
Replacing a control arm (i think) should not do anything but its possible you hit or go dirty a wheel speed sensor.
DHK is offline   Reply With Quote
Old 10-24-2012, 10:46 AM   #4
cimca4120
thanks guys will check on them, this might sound crazy but were are this sensors located?
will take the car to alignment today
Old 10-24-2012, 10:48 AM   #5
scarede46er
realoem.com is your friend. Enter the last 7 digits of your VIN and it will tell you everything. But this thread has the location and part number copied from there for your convenience. http://forum.e46fanatics.com/showthread.php?t=555765
Old 10-24-2012, 11:10 AM   #6
cimca4120
scarede46er thatīs for the rear sensor I need to locate the front sensor, still searching there hope I can find it, thnkx.
