Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
have DRL on at all times
is it possible to have my drl lighs on at all times even when i have the Xenon lights on?
#2 |
You want them on when your headlights are on? That's going to blind oncoming drivers if you run them at night time. They're pointed significantly higher than your main headlight. And as far as I know it isn't possible in the computer. Probably with hardware modification
-Chris
#3 |
how does having drl on blinds on-coming traffic they only operate at 20-30% power.
#4 |
it's still pointed directly at them
-Chris
#5 |
again drl run at 20% to 30% power which is not blinding to oncoming traffic.
#6 |
No, can't be done.
For Sale: Auto Trans E-fan - http://forum.e46fanatics.com/showthr...3#post12840603 23.5mm Front Sway Bar - http://forum.e46fanatics.com/showthr...0#post13054250 18mm Rear Sway Bar - http://forum.e46fanatics.com/showthr...8#post13054258 |
#7 |
use angel eyes instead of DRL, its on all the time...
![]() Last edited by pinoybmr3; 10-24-2012 at 01:50 PM. |
#8 |
personally, i wouldn't do it. its your car, but i wouldn't say for sure it doesn't blind oncoming traffic until you see it from an coming cars point of view at night time. my opinion, not gospel. i double checked my LSZ's option, and there isn't a way to code it in my car.
-Chris
#9 |
#10 |
i do not need your opinion on this as to what is the point of having my DRL to run at full power. if anyone knows a work around on how to have the DRL run at full power while xenon lights are on please share...
do not share your opinion or legality of this... my headlights are modified and running the DRL at full power does not effect the oncoming traffic.
#11 | |
now that you have made it more clear, I haven't seen a way in the coding system to do this and am not sure there is a program written to do it. So unless you can write software yourself to recode the computer then I think your pretty much outta luck. |
#12 | |
MR.CLEAN ;)
#13 |
I too would like to run the inner halogens (at full power) along with the bi-xenons when on high beam.
This would give better light penetration down the road, I find the xenons illuminate the road in front of the car and landscape on either side well enough, but not enough light is focused straight ahead. I can see a way to do this with relays, but re-programming the lighting controller might be easier. |
#14 |
I could've sworn I seen someone do this already, I may be wrong
![]() Last edited by KaliVertBoy; 11-11-2012 at 08:51 PM. |
#15 |
i have bixenon
#16 |
MR.CLEAN ;)
I know I realized that after I stated that just to lazy to edit it lol.
#17 |
This can be done by coding the car using software such as NCS Expert. However, I believe it will only allow for highbeam to come on at same time as xenon, not reduced power drls.
M3 Vert TiAG/Blk - with every option
Mods: Clear Bra | Tints | Hardwired Passport SRX | Painted Bumper Reflectors | Keyhole Cover | 6000k Predator Chromiums | 6000k Philips Ultinons | 6000k HID Fogs | Philips Silvervision Corners | OEM LED Tails | Trunk Lip Spoiler | Eisenmann Race | CSL Diffuser | CD/DVD Swap | Small Antenna | Blackout Grille and Gills | Smoked Corners Mods ready to install: Paddle Upgrade | ZCP Rotors | CF Interior Trim |
