E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 10-24-2012, 08:44 PM   #1
Mhnd
My Ride: 2004, 330XI
Starter Replacement on XI Automatic from above without removing Intake Manifold
2004 E46 330XI Starter Replacement:
I created this DIY to help others who are having issues with removing the Starter on an E46 XI automatic transmission. Most DIYs explains how to do it from under the car (not possible for this model) and others required removal of intake manifold to get access to the starter from the top. In this DIY all work is done from above and there is no need to remove the Intake manifold. I tried to include as many pictures to give the DIY’ers a clear idea about what to expect and how to get around by removing parts to get access to starter. The steps are not in order and exact details. I’m sure you can figure out the missing details while at it.
See attached PDF file for the DIY:
330xi AT Starter Removal.pdf
PDF Link:
http://forum.e46fanatics.com/attachm...9&d=1351129274
Mhnd is offline   Reply With Quote
Old 10-24-2012, 09:07 PM   #2
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
Thanks!
redbull 325is is offline   Reply With Quote
Old 10-25-2012, 10:02 PM   #3
TerryTouring
My Ride: 2002 325xiTouring
awesome
Sure to save time and effort for many of us!
TerryTouring is offline   Reply With Quote
Old 10-26-2012, 04:54 AM   #4
Rickna
My Ride: '01 330xi - '09 IS-F
Great writeup! Thanks!
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 10-26-2012, 07:27 PM   #5
White_Knuckles
My Ride: 2003 325xi
Nice details and... Well done!
Wow, that new starter is a beast! Looks like they made a couple fixes and added beef.
Old 10-26-2012, 09:01 PM   #6
Mhnd
Thanks.
It cranks right away and even much faster than original!
Old 10-26-2012, 09:05 PM   #7
Mhnd
Thanks all .....
I benefited a lot from this Forum and the different DIYs that it offers and this is my contribution back to show my thanks and appreciation.
Old 11-23-2012, 09:21 AM   #8
99magna
My Ride: 2to4
Thank you , where did you buy the replacement starter ?, why you said do not touch one of the big bolt with exposed wire ?, i don't understand please explain.
99magna is offline   Reply With Quote
Old 11-23-2012, 10:39 AM   #9
99magna
My Ride: 2to4
oops, my bad. I see why now you said do not touch that bolt with exposed wire lol.
Old 11-23-2012, 03:23 PM   #10
Mhnd
BMAparts.com $115 after you return core. What I meant is you don't need to remove it or do anything with it.
Good luck.
Old 01-03-2013, 07:42 PM   #11
UnoriginalUsername
My Ride: 2003 320i
Thanks for this. I was doing the "from under" approach right now. the transmission thing is annoying. I don't think I want to remove/losen anything overly mechanical. Spent 2+ hours in the cold and snow just to jack it up. I had to lower it again cause the ramps are made of plastic(albeit, the industrial type). This is gonna make it a lot more easier for me. Thanks again.
UnoriginalUsername is offline   Reply With Quote
Old 01-03-2013, 08:04 PM   #12
UnoriginalUsername
My Ride: 2003 320i
actually, i have a question: I can't seem to find the vacuum cylinder.
Old 01-08-2013, 10:55 AM   #13
Mhnd
I'm not sure why! but my car is an xi model and it was there as described above! Maybe on your car it's in a different location!
Good luck
Old 02-01-2013, 07:44 PM   #14
wildcat293
My Ride: 325xi
thanks!
looks like cold weather really getting to us all =)
wildcat293 is offline   Reply With Quote
Old 02-06-2013, 10:22 AM   #15
Mhnd
Unfortunately
Old 02-17-2013, 07:57 AM   #16
wildcat293
My Ride: 325xi
Great DIY worked great.
a few more notes/tips
I had to take out the bolt on the dipstick bracket and push the dipstick out of the way to get to the nut on the vacuum canister. Even then I could not get a socket on it but a 13mm wrench worked great.
I did not have to break the metal bracket holding the fuel line. If you do break it it might be part 12527513286 but not sure.
The locating pin came out attached to my old starter. Made it harder to line up but not an issue.
Pop out the brake booster (just pull really hard) and unbolt the B+ wire at the jumper location for more working room.
Old 02-21-2013, 01:51 PM   #17
Mhnd
Great I'm glad you got it all fixed and thanks for the notes .....
Old 01-17-2014, 04:51 AM   #18
Mhnd
Attachment 475389
PDF Link:
Old 08-04-2014, 05:52 PM   #19
jmo69
My Ride: 03 325xi 98 328is
I'm in the middle of this DIY and just got the old starter out. I ordered my new one before the old one was out and to my dismay I'm one of the lucky ones that have the Denso starter. Fortunately I caught the order in time and got them switched. I used a ½" deep well socket with swivel and 3 extensions to break the vacuum canister nut loose. I'm not looking forward to putting the starter bolts back in with so little room to thread them in by hand. I used a Blue Point ratcheting box end to get them out but with only enough room to get less than an eighth of a turn, it took forever especially when it was loose enough that the wrench wouldn't ratchet but was to tight to turn with my fingers. I bought a set of Craftsman specialty wrenches and planned to use the 12mm to break them loose but it was too big and the 10mm seemed a little loose too. I was going to take them back but once I had the bolt out I found the 10mm fit as well as the 3/8" gear wrench but not as tight as the e12 socket. Hopefully in 3 days this will all be done and I suppose saving the cost of a tow, list price and $75/hr will be worth it. At one point, once I could access the main cables I snugged them down, and tried the key to no avail, but after loosening and retightening them and tapping the solenoid I could get it to engage. I didn't let it crank and made the decision to replace it anyway. I don't want to ever have to do this again.
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 08-11-2014, 11:24 PM   #20
jmo69
Just finished this job, things went back together easier than I thought it would. A few tips, don't drop the top starter bolt, I did but got lucky in that I could see it sitting on top of the trans with a mirror and was able to knock it off and down to where I could reach it from below. After that I put a slipknot in a piece of monofilament fishing line and attached it to the bolt with a few wraps around it. I then used my "mechanic's fingers" to hold the threaded end and guide it into the hole and then I could push it into place and pull the line and have it thread into the starter a few turns. The vacuum canister nut can be re-installed from below with a ratchet and socket, removal was done with extensions and a swivel on a deep 13mm from above. Took me about 4 hours to finish, I just have to put the belly pans back on.
Hers His
