Old 10-25-2012, 06:04 PM   #1
.DatBlackBM.
My Ride: 2003.5 M3 6spd
Spacers for M??
Just upgraded to an M about 2 weeks ago. WIth winter coming up i want to tuck the 19's away and throw on the 17' winter set-up i had on my 330ci but im not sure what size spacers i need to clear the breaks or if i need spacers in both front and back. Also i have csl m3 brakes* installed which adds to the confusion. Here are pics of the 19's and the 17' asa's i want to replace them with(all 4 rims are 7.5 inch's wide and all 4 tires are 205/50/17) Any help will be appreciated. Thanks
ID:	475527   Click image for larger version
ID:	475528   Click image for larger version
.DatBlackBM. is offline   Reply With Quote
Old 10-25-2012, 07:26 PM   #2
invictus
My Ride: M3 (F80 & E46), S3R
you might be SOL with clearance on the CSL rotors and 17s. 17s barely cleared the OEM size as I recall...
Testfit and look?
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
Old 10-25-2012, 11:53 PM   #3
fiveightandten
My Ride: '03 330ci / '98 M3
Brakes, not breaks.
Test fit. If they clear, go to the hardware store and pick up a bunch of large nuts and washers to space the wheel out. You can get away with putting them on 3 points on the wheel. Get the car off the ground, bolt the wheel up with different combinations of washers and and nuts until you get proper clearances. Measure the thickness.
-Nick
fiveightandten is offline   Reply With Quote
Old 10-26-2012, 06:14 PM   #4
.DatBlackBM.
So if they do fit purchasing spacers from let's say.. bimmian wouldn't suffice?
