Sponsored by BimmerWorld
Old 10-25-2012, 06:54 PM   #1
TickleMyPickle
My Ride: 2001 330xi
!help! Rear wheel camber problem
so today was a pretty horrible day for the 330, i got a flat on my way to class with no spare, i finally got the car home and got the stock wheels on . And now to top of this wonderful day i was backing my car into my drive way and the car suddenly stopped as if the emergency brake was up, i tried to pull the e-brake and it wouldn't budge. i get out of the car and see my rear passenger wheel is cambered in at like a 35 degree angle Then i put the car in drive and it straightens out and the e-brake is back to normal what an amazing day. Someone please helpppp
You almost had me?
You never had me, you never had your car
Granny shiftin' not double clutchin' like you should.
You're lucky that hundred shot of NOS didn't blow the welds on the intake!
TickleMyPickle is offline   Reply With Quote
Old 10-25-2012, 06:57 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
You have to take the tire off and look.
Old 10-25-2012, 06:57 PM   #3
asma123
My Ride: E70x5 m3conv m3coupe
pics or it didnt happen
asma123 is offline   Reply With Quote
Old 10-25-2012, 06:58 PM   #4
TickleMyPickle
My Ride: 2001 330xi
thank you captain obvious, i just wanted to see if anyone has had these symptoms before i lift the car up tomorrow.
You almost had me?
Old 10-25-2012, 07:01 PM   #5
My Ride: Lexus
i've never heard of that... sounds like your trailing arm disconnected from its pocket somehow. just a guess
Old 10-25-2012, 07:03 PM   #6
TickleMyPickle
My Ride: 2001 330xi
You almost had me?
Old 10-25-2012, 07:14 PM   #7
My Ride: Lexus
Originally Posted by TickleMyPickle View Post
ouch.
what led to this? tow truck driver did this? that trailing arm or other major control arm has gotta be totally busted. or the trailing arm mounting point may have failed from corrosion/stress
Old 10-25-2012, 08:51 PM   #8
TickleMyPickle
My Ride: 2001 330xi
Sent from my SPH-D710 using Bimmer App
You almost had me?
Old 10-25-2012, 09:01 PM   #9
Zell
Zell's Avatar
My Ride: so turbo wow
That....that uh. Wow. That really sucks.
Old 10-25-2012, 10:40 PM   #10
winstontj
My Ride: a car
OP all I can say is that you are so incredibly lucky that it happened in your driveway at <1mph.
winstontj is offline   Reply With Quote
Old 10-25-2012, 11:04 PM   #11
TickleMyPickle
My Ride: 2001 330xi
I know what An amazing day
You almost had me?
Old 10-26-2012, 10:25 AM   #12
My Ride: Lexus
looks like someone strapped the car down using the lower control (camber arm) yikes! good thing is that's an EASY repair. you are lucky the trailing arm pocket didnt break.
Old 10-26-2012, 10:27 AM   #13
99_323i_Steve
My Ride: 1999 BMW 323i
whew, brutal. imagine going on the highway with that happening...
I've learned some people think their a mechanic when they can do their own oil change. Don't always believe what you read.
99 323i. Factory:Harmon Kardon Hi-Fi, Winter Package w/ heated sport seats, and Sport package with Sport steering wheel and Sport suspension.
Aftermarket: 16" rims, LED Angel Eyes, LED license plate lights, LED tails, LED depos, Black kidney grill, and DICE Aux jack input, 20% tint.
99_323i_Steve is offline   Reply With Quote
Old 10-26-2012, 10:46 AM   #14
jdstrickland
Where did you put the jack? Not on the jack pad, right?
You jacked from the control arm and broke it. My neighbor jacked his car from the control arm, and cut through the wire that goes to the speed sensor.
Sorry man, it sucks to be you these days. You should replace both control arms and the bushings. You only _have_ to replace the broken part, but smart money would replace the same part on the other side, and the bushings where the parts that move meet parts that do not move.
For future reference, the jackpads (which you should always use) are located forward of the rear tires where the fenderwell and the main part of the body come together, and under the hinge of the front doors straight down from the A-pillar.
Old 10-26-2012, 01:24 PM   #15
TickleMyPickle
My Ride: 2001 330xi
i only jack my car up from the jack pad i guess while i was backing into my driveway that wheel got up first and the stress cracked it , i just got the car in the air gonna attempt to fix this
You almost had me?
Old 10-26-2012, 01:27 PM   #16
My Ride: Lexus
hope you know you need an alignment afterwards
Old 10-26-2012, 01:29 PM   #17
choxor
My Ride: JDM
Something had to cause that.
