Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Pacific Northwest
Pacific Northwest
AK HI ID OR WA
Old 10-25-2012, 08:47 PM   #1
jizzzoe
My Ride: is no longer E46 :(
Send a message via Yahoo to jizzzoe
Looking for used/rebuilt steptronic tranny
...for 2003 330Ci. Whatcha got?
My Steel Gray '03 330Ci... I miss you, baby!
MODS: Purely aesthetic… Shadowlined, Smoked and LED'd out!
jizzzoe is offline   Reply With Quote
Old 11-27-2012, 12:20 AM   #2
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Why are you looking for a rebuilt tranny? Curious.
/// MODS
Old 11-27-2012, 12:41 AM   #3
3coupe
My Ride: 330Ci
I have a used auto I took out when I did my 5 speed swap. I can ship for the right price.
It's off a 2001 330ci.
3coupe is offline   Reply With Quote
Old 11-27-2012, 01:27 AM   #4
TitaniumCranium
/// Limitless
Just looking out for everybodies interests here - jizzzoe you need to make certain that the tranny is the same make, i.e. the 2001 tranny is most likely a ZF, although there are some instances reported of GM instsalls (factory freaks). The GM is not interchangeable with the ZF. They use different EGS modules and the wiring connections are different. According to records GM trannys were installed in 330CI's after 2003/03.
The reason I ask why you need a rebuilt is that I was pulling code P0741 on my tranny (ZF). The transmission felt kinda loose, and I was feeling surges occur at about 2000 rpm, it would jump up to 2400 rpm but the car wasn't going any faster. If I floored it, the kickdown would go into affect but the tranny was slow to actually put the power to the ground. I replaced the tranny with a manual. Upon inspection the only problem was that the "O" ring inside the torque converter was cracked causing the tranny fluid to bleed by the torque converter back to the transmission. My original tranny is still living in another fanatics car without any additional work.
/// MODS
Old 11-28-2012, 03:13 AM   #5
jizzzoe
I blew my oil cooler and then drove the car for 4 or 5 miles, toasting the tranny. I ended up getting a used one through my indy mechanic for $1500. Same miles as my car (110k) and 6mo/7500 mile warranty. Total bill with oil cooler and everything $3258
Old 11-28-2012, 03:15 AM   #6
jizzzoe
Thanks for the tips though Titanium!! Good lookin out!
