Old 10-25-2012, 08:43 PM   #1
socal330cic
My Ride: 330cic
Engine misfiring, pcv looks fine...
Alright so my car has had a very rough idle since I got it though I haven't really been driving it. Turned it on last week and it shuts down immediately. Looked under the hood and saw the upper and lower intake boot were torn into pieces. Put on new ones yesterday and now it stays on but still the rough idle. (shaki g engine and bouncing rpm) I went and bought a code reader and came up with all of this:
P0313
P0300
P1344
P1349
P1351
P1346
P0174
P0313
P0300
So I do some research and decided to go replace the pcv valve and pipes as they're probably in the same state as my intake boots. Just finished taking all the hoses off the pcv and they all look completely fine. All are still flexible with no apparent holes. I'm thinking it's possible po may have changed them. Is it worth installing them anyway or should I return them? I'm on a college budget so if they're not bad I need the money to fix whatever is wrong. Is there a way to test the pcv or tubes once they're off the vehicle?
socal330cic is offline   Reply With Quote
Old 10-25-2012, 08:45 PM   #2
socal330cic
My Ride: 330cic
Car is 2001 330ci with 130k
Old 10-25-2012, 08:45 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the first 2 links below in my signature.
Old 10-25-2012, 09:04 PM   #4
socal330cic
My Ride: 330cic
That's actually where I read and decided to try the pcv. DISA looks fine though dirty, icv looks slightly dirty. Is there a way to test the old tubes and pcv?
Old 10-25-2012, 09:07 PM   #5
jfoj
Suggest you check the CCV lower oil return line as this is a very common problem and pretty cheap and easy to change. The CCV probably need to be replaced, but the oil return line can buy you some time.
Also valve cover problems, oil fill cap and dip stick O-rings are something to look closely at.
Old 10-25-2012, 09:30 PM   #6
socal330cic
My Ride: 330cic
Looking at my oil return line it looks fine. I just made a video showing condition of parts so far. Any input is appreciated.
Old 10-25-2012, 09:41 PM   #7
socal330cic
My Ride: 330cic
Alright I wrapped a glove around one and of the two pcv pipes and blocked the other end and tried to blow. Held the pressure so the hoses seem fine. Should I go ahead and replace them or is there someway to tell if the pcv is bad after taking it out?
Old 12-09-2012, 03:52 PM   #8
TEAMAFLCON
My Ride: 2003 325i
I changed the PCV and the white smoke was gone....SES/CEL went away after replacing the PCV.
2 months after, the SES/CEL came on and the rough idling started.
Code read P1351 (#5 coil).
Did the following and the test worked fine, going to install a new BOSCH coil from autozone for $34, I'll let you know the results tomorrow
TEAMAFLCON is offline   Reply With Quote
Old 12-11-2012, 09:37 AM   #9
TEAMAFLCON
My Ride: 2003 325i
Installed coil... problem solved. Running normal. SES light still on, I'm hoping a few miles of driving will reset it.
Sent from my PantechP9070 using Bimmer App
Old 12-12-2012, 03:29 PM   #10
TEAMAFLCON
My Ride: 2003 325i
SES light turned off.
Looks like it worked.
Old 12-12-2012, 03:33 PM   #11
Ruthlessone3k
My Ride: 323i
Great! Glad to see you are back up and running. Thanks for following through with the results.
Ruthlessone3k is offline   Reply With Quote
