Old 10-25-2012, 10:04 PM   #1
E46Cherry
My Ride: 2003 M3
DSC vs Rain
We've had plenty of hard rain here in the midwest the past few days. When it's raining fairly hard where water seems to collect on the roads, I find it much easier to drive with the DSC off. Anyone else seem to notice that DSC is quite sensitive and at times too dangerous?
E46Cherry is offline   Reply With Quote
Old 10-25-2012, 10:06 PM   #2
j_block
My Ride: 2003 325i
Wtf? Why would you turn it off
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 10-25-2012, 10:06 PM   #3
Grande D
My Ride: E36 M3
No, DSC is not dangerous. DSC kicks ass. ASC and the old programs could be dangerous.
It will change your life!
Old 10-25-2012, 10:09 PM   #4
E46Cherry
My Ride: 2003 M3
it seemed like it was actually swerving more with it on for some reason. when I turned it off it felt like I had way more control of the car!
Old 10-25-2012, 10:10 PM   #5
tock172
My Ride: '12 135i DCT
You're using too much throttle.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 10-25-2012, 10:10 PM   #6
choxor
My Ride: JDM
No
Old 10-25-2012, 10:13 PM   #7
Zell
Zell's Avatar
My Ride: so turbo wow
That's what it's designed for...I never ever ever turn mine off.
Old 10-25-2012, 10:13 PM   #8
E46Cherry
My Ride: 2003 M3
I guess that's a possibility. Usually I would start driving before it even rains and mostly on the highway. By the time it starts raining, I was so used to maintaining an 80-90mph range that I could be using too much throttle
Old 10-25-2012, 10:17 PM   #9
tock172
Old 10-25-2012, 10:20 PM   #10
E46Cherry
My Ride: 2003 M3
lol
Old 10-25-2012, 10:27 PM   #11
tock172
You will not be laughing when you wreck.
Old 10-25-2012, 10:30 PM   #12
E46Cherry
My Ride: 2003 M3
well I wasn't going that fast. I slowed down to how traffic was going which was like 50 but I still felt more swerving OR the car trying to maintain a straight path in curves.
Old 10-25-2012, 10:39 PM   #13
tock172
What is the condition of your tires and what brand & model are they?
Old 10-25-2012, 10:42 PM   #14
jfoj
My Ride: 330CiC, M5, X5
Sounds like you are hydroplaning?? Suggest you slow it down a bit.
DCS is generally a good thing, except in my M5 when you have to turn it off if you plan on hopping on the throttle hard.
Nothing worse than having your ignition timing retarded heavily and your drive by wire throttles shut down when you are trying go get out of the way quickly!
Old 10-25-2012, 11:00 PM   #15
E46Cherry
My Ride: 2003 M3
I have michelin Pilot Sport PS2 on the M3. same ones since I bought the car about 2 months ago. it's possible I was hydroplaning. I just thought it was the DSC cause when I turned it off, it seemed I had a little more control. But then again there were still times I had the same symptoms with the DSC off.
Old 10-25-2012, 11:09 PM   #16
choxor
My Ride: JDM
This isn't an issue with DSC. It's an issue with you not being able to control the car properly. Slow down.
The real question is why you decided to turn the traction control off while driving in heavy rain. It doesn't seem like the smartest move.
Old 10-25-2012, 11:19 PM   #17
///MPR77
My Ride: 02 ///M3 Tri-Ped
My DSC hasn't been on for years....I think the module is bad.
I did have an issue when it was working, and shortly before it went out, where I changed only my rear tires on a road trip they had a softer treadwear rating than the fronts fwiw, and i noticed on a freeway merge ramp (a long bending curve basically) going about 50mph I felt a fierce vibration in the pedal, and DSC correcting for no reason...indicator flashing etc.. it felt very dangerous. I know what a properly functioning DSC feels like, and this was nothing at all like that.
Old 10-25-2012, 11:41 PM   #18
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
this.
if you're activating the dsc in rain you're doing something wrong. i can drive pretty hard without even making the light blink. i have brand new tires and suspension though so you car might be falling apart. just saying.
Old 10-25-2012, 11:44 PM   #19
Alex323Ci
My Ride: M3 & 323Ci (sold)
unless you've take some driving/track courses, i highly suggest you keep it On. an M3 with DSC off in the rain is an M3 rear end into a tree/pole waiting to happen.
Old 10-25-2012, 11:45 PM   #20
fiveightandten
My Ride: '03 330ci / '98 M3
DSC works impeccably in the rain. It does exactly what its supposed to do. Yes, it's intrusive. But it will correct the car before it gets into trouble. You have to be trying quite hard to do something stupid enough to crash the car in the rain while the DSC is on. Believe me, i've tried plenty of times when I was getting a feel for how the system intrudes. If you drive sensibly, the system will keep you safe.
Driving 90 MPH in the rain is not sensible. I mean this in the nicest way possible...you don't sound like you can control the car well enough to bring it back from an unexpected loss of traction in the wet. Keep the system on. I've been autocrossing for a number of years. I've raced in the rain and i'm quite familiar with driving the car past the limits of adhesion in the wet. I keep the DSC on when i'm driving on the street in the rain. There's no reason not to.
Be safe.
-Nick
fiveightandten is offline   Reply With Quote
dsc, m3, rain, snow, weather
