Off-center steering wheel - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-25-2012, 09:07 PM   #1
Mike.Santos999
My Ride: BMW E46
My steering wheel is a bit off center. Would that indicate bad alignment or it may just need a little adjustment? Where and how? Car drives straight and does not pull left or right...if that would rule out alignment issue
Sent from my Android using Bimmer App
Regards,
Mike
The SCTEX Midnight Driver
Mike.Santos999 is offline   Reply With Quote
Old 10-25-2012, 09:10 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Textbook alignment issue.
Also a possibility, if someone ever took off the steering wheel, they might not have aligned the hatch marks.
Old 10-25-2012, 09:12 PM   #3
bikesandcars
My Ride: 2002 325xi-sport pkg
Bad alignment technique at minimum. Many shops make adjustments but don't center the wheel. If your spension isnt worn then suggest taking it to a shop for a proper lineup ( or do it yourself with string if you are bold)
Sent from my MB855 using Bimmer App
bikesandcars is offline   Reply With Quote
Old 10-26-2012, 02:03 AM   #4
illestminimike
My Ride: Project Drama
Handle it before you start getting steering angle position codes.
Old 10-26-2012, 07:22 AM   #5
WDE46
My Ride: '13 128i, '04 330Ci
mine is off center as well, but I was the cause of it. When I replaced my steering guibo I had to let the wheel turn to get it to slide on. Anyway, the off center will cause your DSC to intervene too early if you turn in the direction it is biased towards and too late for the opposite side. You should get the alignment done as soon as you can.
