Little issue with removing headlight assembly. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-25-2012, 10:27 PM   #1
TArse
My Ride: 03 330xi, 87 325is
I tried to remove my headlight assemblies on my facelift 330xi with headlight washers today and I ran into a little problem.
I got the headlight unbolted, wire connectors disconnected and ready to remove.
Then I say two wires going into the assembly that could not be disconnected, or so it seemed.
The wires were connected to the headlight computer(i think that's what it was?)
Has anyone else ran into this and care to shed some light?
TArse is offline   Reply With Quote
Old 10-26-2012, 01:50 PM   #2
haurelio
My Ride: 2001 bmw 325i
Not sure what cables are you referring to, but in any case just unclip them..
Old 10-26-2012, 02:40 PM   #3
TArse
That's the issue, I couldn't find a clip. I check both assembly's and couldn't not figure it out. I will take pics next week and post
Old 10-26-2012, 07:37 PM   #4
haurelio
Ok. Are they oem headlights? Does the light have the cleaning option?
Old 10-27-2012, 05:08 AM   #5
TArse
Yea they are the oem bi xenons with the headlight washers.
Old 04-20-2016, 02:34 PM   #6
TArse
Going to bump this post.
My xenon started working again shortly after I originally posted and I never figured out how to get my assembly out of the car.
So now my xenon has gone out. I swapped bulbs and the same side is out, so that rules out the bulbs.
I want to swap my igniter and computer on each to figure out what I need to buy to solve this issue.
My problem is that every video or DIY I see about removing the headlight assembly is so simple.
1. Remove blinker.
2. Remove bottom trim and headlight washer.
3. Remove the 4 bolts on the headlight assembly.
4. Remove the assembly while disconnecting the plugs.
In my case when I get to step 4 there are two wire that run INTO the assembly and do not have a plug, they run to what looks like the control module for the headlight, but again they run into the module and do not have a clip. These two wires are preventing me from removing the assemlbly as they run the another part bolted to the car which is near impossible to get to while the assembly is still on the car.
I will post a picture in just a few minutes hopefully someone can point out what I need to do, but as of right now I am stumped.
Old 04-20-2016, 02:51 PM   #7
TArse
I think I may have figured out the issue.
The wires do indeed run the the control module. I just removed the passenger side assembly easily, but on the drivers side my Dinan longtube (installed my previous owner) runs right where the module should be and the module is bolted off the the side, I think. It's hard to see. I'm going to remove my intake and see if I can get this figured out.
Old 01-30-2017, 10:38 PM   #8
TArse
The post above is correct and my module is bolted in a different location.
