E46 Convertible
Old 10-26-2012, 08:07 AM   #1
Paulbateman
My Ride: 325ci convertible
Softop/hardtop
I'm looking at purchasing a hardtop for my 325ci , will it just clip right on or is there anything else I need to purchase to make it fit ?
Paulbateman is offline   Reply With Quote
Old 10-26-2012, 08:34 AM   #2
R1200RT
My Ride: 2004 330CIC
It should fit right on. Most European verts came with the hardtop installation kit right from the factory. Just slide the small covers back and look to see if they are installed and you are good to go.
Link from thread below for what to look for,
http://www.m3forum.net/m3forum/showthread.php?t=146764
Nick
'04 330CIC, 3 pedals, M Sports\Aerodynamics Packages
'05 BMW R1200RT
'00 BMW R1100S
'04 BMW R1200C Montauk
'95 BMW R100R Classic
R1200RT is offline   Reply With Quote
Old 10-26-2012, 04:03 PM   #3
billyp
My Ride: alpina b3s vert 3.4
On my third uk vert and the same hardtop has been sprayed and used on all, you will see 2 wee square shaped covers near where the covers slide back, gently prise them off and you will see where the pins on the hardtop locates
billyp is offline   Reply With Quote
Old 10-26-2012, 05:32 PM   #4
Paulbateman
Thanks both ill check on a good day if everything's set up & I'll let you know
Old 10-26-2012, 06:03 PM   #5
bimmernut3
My Ride: '05 330cic, '01 540i
@Paul...Here are pics of my left & right sides with the small plastic covers removed showing the Hardtop prep kit I installed yesterday in my '05 330Cic. The earlier E46's allows for these covers to slide back. The later models 'pop' out. In either case, you should see the hardtop locking ports installed with the electrical contact on top. If you don't have these, you will need to order the prep kit. BTW, Taylor192 has a kit for sale here http://www.e46fanatics.com/forum/sho...8#post14844658
Drivers side
Passengers side
'05 330ci
[IMG][/IMG]
bimmernut3 is offline   Reply With Quote
Old 10-26-2012, 07:56 PM   #6
Paulbateman
Great pics bimmernut3 , can't say I've noticed. Then on my car but I will update When weather permits , thnx
Old 10-27-2012, 01:22 PM   #7
Paulbateman
Been & checked today , yeah my car has the kit already fitted
