Old 10-26-2012, 12:24 PM   #1
ataan
My Ride: e46 318
locked out, only trunk can be opened
Hello everybody, I do need your help.
My remote control won't work any more Though, it can sometimes turn on the room lights. The door lock is already broken!
The only thing I can open is the trunk. Is there anyway I can get into my car without breaking anything?
P.S> the car is an e46 3 series 03
ataan is offline   Reply With Quote
Old 10-26-2012, 07:44 PM   #2
Fajitas
My Ride: 04 E46
I had a friend of mine's young daughter climb through the ski pass in the trunk to unlock the doors.
Fajitas is offline   Reply With Quote
Old 10-26-2012, 09:00 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If you don't have a ski pass you can make one pretty easily.
If you have a coupe, you can pry out the window enough to get some hook on the door handle and pull it open.
I don't know if you can fold down seats from the trunk if you do have split, folding seats.
Making a skipass isn't a big deal...search for it.
HTH
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 10-26-2012, 09:01 PM   #4
E46inthe206
My Ride: 2003 BMW 330Ci
Yeah.. open the trunk, pop the rear seats down, climb in..
E46inthe206 is offline   Reply With Quote
Old 10-26-2012, 09:57 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Note on the door handle being pulled.
You likely will have to push the center locking button before you actually try to pull the door handle to open the door.
Time to get a new keyfob and repair your driver door lock linkage.
Check ebay as you can get the replacement door lock linkage for around $25 US.
