Old 10-26-2012, 03:27 PM   #1
Nicks330i
My Ride: 330i
E46 330i bank 1 & 2 lean
Hi guys I been having this problem for a while and I saw many people yelling me its the oil separator so I whent ahead and replaced that with all the vacuum hides that are connected to that and the canister but the problem is still there has any body run into the same problem? If so how did you resolved it.
Nicks330i is offline   Reply With Quote
Old 10-26-2012, 03:29 PM   #2
Brinkley
My Ride: 99 328i, 07 z4 3.0
Search for jfoj, he has a comprehensive thread on such codes and there's a lengthy discussion. Could be Disa, could be a tear in the intake boot, could be a lot of things.
Brinkley is offline   Reply With Quote
Old 10-26-2012, 03:29 PM   #3
My Ride: Lexus
Two systems are the likely culprits for these codes:
FUEL
VACUUM
Address both. See sig, click 3rd link entitled JFOJ, do it. Hit the back button, see sig again--do it all!
GL!
Old 10-30-2012, 12:04 AM   #4
Nicks330i
My Ride: 330i
After reading the post I'm deff testing the disa valve does any body know how to test the engine vacuum purge valve?
Sent from my HTC_Amaze_4G using Bimmer App
Old 10-30-2012, 04:36 AM   #5
Bimmerguy82
My Ride: 2004 ZHP 6 SPD
I had the same codes and it was my lower intake boot was torn and had a vacuum leak.
BMWCCA member #407674
___________
-Joshua
ZHPMafia.com member
Ebay headers | 3.38 diff | 2.5" cat-less exhaust | K&N intake | AA stage 1 software | UUC stage 1 light flywheel and clutch | UUC Evo 3 ssk
Bimmerguy82 is offline   Reply With Quote
Old 10-31-2012, 03:15 PM   #6
Nicks330i
My Ride: 330i
Well I just replaced this items
Upper and lower intake boot
Oil separator and hoses that connect to it
Vacuumhose that connects the intake and the canister
And replaced the fuel filter
After that I turned on the car spray some carb and choke cleaner to make sure I didn't miss anything and today I reseted the check engine light well see what happens. I'm hoping this fixes the problem other wise I'm looking into the Disa or the vaccum valve that's under the front of the intake manifold.
Old 12-12-2012, 01:43 AM   #7
Nicks330i
My Ride: 330i
Ok getting back to me problem after replacing the intake hoses, PCB and all the vacuum hoses I still have the lean codes so I switched my idle air control valve but I'm still getting the codes, oh I forgot I tested the disa valve and it was good
When I start the car it idles righ but the I get sporadic idleing would it be the fuel pump, I was maybe thinking the jet sucking valve that is connected to the brake booster, intake hose and the back of the intake or might it be the valve that is under the intake right behing the oil filter housing.
Any suggestions?????
Old 12-12-2012, 06:20 AM   #8
jfoj
My Ride: 330CiC, M5, X5, E93
See 2nd link below in my signature for fuel pump issues, however, if you are getting your CEL at idle, then you problem is not likely a fuel pump issue.
You have missed a problem somewhere unless you or someone have replaced the MAF with a non OE style MAF.
If you have a scan tool that reads out fuel trims, this would be helpful.
Intake path or crankcase air leaks are your likely problem.
You have to methodically check and change most of the plastic and rubber parts out. Did you replace the lower CCV oil return hose that connects to the dip stick?
Did you check to make sure the CCV side vacuum port was plugged if you did not need the port?
Did you check all the hoses under the rear of the intake?
Did you check the DISA and replace the O-ring?
What codes are you specifically getting and when does the CEL come on, idle or cruising? Do you get any misfire codes as well?
