Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 10-26-2012, 04:28 PM   #1
SamDoe1
My Ride: 4cyl of fury
Let's talk water heaters
So my water heater recently took a dump, tank leak that's not repairable, and we are in the market for a new unit. Luckily the one that's broken was still under warranty and we get a $500 credit towards a new one. The broken one was made in 2003 FWIW.
I'm looking for something that's more efficient than what I had so what thoughts do you guys have? Any experience with tankless ones? Any downsides to those? How much on average do you feel you save by switching to a tankless?
Right now it's just my fiance and me (soon to be adding a puppy) in our house but for resale value, I'd rather not put a puny water heater in.
Old 10-26-2012, 04:40 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
It's leaking out of the tank, not just the fill tube? If only fill tube...meaning it's not dripping out of tank, but it's running out of hot water soon, then you could take the money and just replace fill tube...and anode while you're at it.
Try waterheaterrescue.com Saved my tank years ago...need to redo this pretty soon I think.
I think the tankless are considerably more expensive...as in maybe something like $2000+ install...versus getting a tank from HD for maybe $300-500 and installing yourself with a friend.
Might consider a water sensor and automatic shutoff valve too depending on its location.
Can't speak to pay back time for tankless, but the tanks now are super insulated. Biggest virtue of tankless is never running out of hot water...although there too, depends on how much use its getting. With just two people and a puppy, shouldn't be an issue no matter what you get.
HTH...
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 10-26-2012, 06:35 PM   #3
SamDoe1
It's for sure leaking out of the tank. The top fill tube is bone dry and I can feel a hot spot where the water is coming through the insulation about halfway up the side of the tank. The rest of the jacket is cool to the touch. Also, the hot spot is on the opposite side of the tank from the relief and drain valves.
The leak is really slow and hot water supply hasn't diminished at all but I'm getting this resolved before it gets worse.
Old 10-27-2012, 04:24 PM   #4
Guest100615
Account closed per your request
If you are talking resale, then I am assuming you are not going to be there long.
Just get a 40 or 50 gallon water heater from Home Depot or Lowe's.
You can buy one and get it installed for 600 or 700 bucks.
And it will be more efficient than the one you have.
If you are going to install if with a friend, make sure you fill the water tank with water BEFORE you cut it on.
Otherwise , if you cut on the water heater before, or while it is filling with water; the heating element will pop when it contacts water and you will have to replace it. Ask me how I know.............
Guest100615 is offline   Reply With Quote
Old 10-27-2012, 10:41 PM   #5
Maniac
My Ride: platinum ecoboost R6
I'm a gas fitter and work for a heating company that installs 100s of on demand water heaters. They are "on demand" NOT "instant hot water"
I'd never put one in my house they are noisy, take way to long to get hot water to faucets, so many things to go wrong causing you to have no hot water
And very expensive
We install Nortiz navien Bosch and rinnai
<img src=http://i194.photobucket.com/albums/z76/E46Maniac/signumber2.jpg border=0 alt= />
Originally Posted by 46_coupe View Post
Attractive and stable works for me...I'd rather help wifey program the stove clock than wonder if she purposely left the gas on :eek:
grey green metallic-gone
platinum ecoboost on 35 toyo MTs
Maniac is offline   Reply With Quote
Old 10-28-2012, 07:03 AM   #6
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
tradition hot water heaters give you a ton of emergency water for survival.
...just sayin.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 10-28-2012, 07:09 PM   #7
SamDoe1
We just moved in, just planning for the future though! We ended up getting a replacement 50gal 40k BTU 12 year tank as our exchange. It was the equivalent best unit so it didn't cost anything out of pocket.
Just spent the afternoon installing it and learned a lot about plumbing in the process. No water leaks and no gas leaks so we're good.
Thanks for the advice, I did fill the whole tank before igniting anything.
And very expensive
Yeah, I haven't heard many good things about them...glad we didn't go with one.
...just sayin.
Old 11-13-2012, 06:56 PM   #8
217Bimmer
My Ride: Dodge Durango
should have went heat pump. minnesota prob has decent incentives to install them. oh well. after this one fails.
** Political signature removed - Tim330i **
I always have to laugh when I see a thread described as "Not Work Safe." Is there anything on the OT forum that's really "work safe"? If I were your boss, I'd be mad if you spent any time on this forum at work at all. How is a picture of a naked girl any less work safe than, say, a picture of a matador getting gored in the *** by an angry bull? - VaderDave
217Bimmer is offline   Reply With Quote
Old 11-15-2012, 03:56 PM   #9
SamDoe1
Not enough to justify the almost triple in cost.
Old 11-27-2012, 12:39 PM   #10
217Bimmer
meh. how much was your new water heater?
you can get hpwh for about $1200 now. 3 times more efficient and doesn't require a flue vent that sucks your conditioned house air and blows it outside. saves a few hundred per year. basically these things make hot water and money.
Old 11-27-2012, 02:32 PM   #11
SamDoe1
Mine was zero cost to me but the retail was $450.
Old 12-23-2012, 07:12 PM   #12
ryanwhite74115
My Ride: 2013 Infiniti G37S
What's the word on these "Hybrid" hot water heaters that combine a regular unit with a heart pump?
Sent from my DROIDX using Bimmer App
ryanwhite74115 is offline   Reply With Quote
Old 12-25-2012, 12:44 AM   #13
Guest100615
Well, there is a national waiting list. It's hard to match donors with matching hot water heaters but God willing, recipients will find a successful match before their heater goes out.
Old 12-25-2012, 07:58 AM   #14
ryanwhite74115
HEAT pump people... HEAT PUMP! Funny post nonetheless.
Old 01-02-2013, 11:32 AM   #15
SamDoe1
Expensive to buy but saves a lot of money in the long run. If I was going to replace the tank at my cost, I would have gone with the heat pump one but mine was a warranty exchange.
Old 01-02-2013, 01:18 PM   #16
ryanwhite74115
I've heard very mixed reactions from these combo units. Some have had them for a few years and they've been awesome...no issues. Others have said nothing but trouble and there is a design flaw that GE acknowledges and fixes everytime...but there is no permanent solution.
Again, I'm an idiot with water heaters and until I bought my house had NO IDEA how much electricity they use!
Old 01-02-2013, 05:37 PM   #17
SamDoe1
Gas water heaters are generally cheaper to run than electric ones. The heat pump heaters use a combination to lower the overall energy consumption.
Every set of reviews I read online was a wash between positives and negatives for every water heater I could find so take reviews with a grain of salt.
Old 01-28-2013, 04:56 PM   #18
217Bimmer
water heating consumes the most energy in your house than any other appliance! next is your dryer!
Old 03-22-2013, 03:51 PM   #19
Riverbmr3
My Ride: MB E350 & BMW 325i
just replaced water heater in my rental house, home warranty company replaced it with Rheem brand, $750 from warranty and $900 from my wallet installed ($1650).
Riverbmr3 is offline   Reply With Quote
Old 03-25-2013, 09:26 AM   #20
Vin Vega
My Ride: 2000 328Ci
dam son $900 to install, I can do that in an hour, and most of that time is to remove the old one.
Vin Vega is offline   Reply With Quote
