Need help with an oil leak. Ive been sesrching... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-27-2012, 09:02 PM   #1
gzagenius
My Ride: 01 m3
Send a message via AIM to gzagenius
This is what it looks like (although its a sample pic)
The leak after cleaning, ive noticed is not the drain plug. Rather its something dripping down from up higher on the passenger side a little further up from this abnormally big bolt that some of you may be familiar with. I was told it could be the rear main seal but am hoping its not. There are no signs anywhere under the hood of leaking, not near the fan, oil filter housing or the left shield on the left side if the motor. Someone tell me it may not be a rear main seal and if it is what $ am i looking at more or less if i bring it to a shop.
Thanks for any input guys.
gzagenius is offline   Reply With Quote
Old 10-27-2012, 09:03 PM   #2
gzagenius
My Ride: 01 m3
I have a 2001 m3 with 90k by the way
Old 11-08-2012, 12:17 AM   #3
silvrXI
My Ride: E46(x2)&E36/7M&YZFR6
"Constant pressure valve". Its a small plug on the upper portion of the block behind the exhaust manifolds. Pretty common and when it leaks, IT LEAKS!!! Whats needed for replacement is a 3/8s drive PHILLIPS bit, basically a large screw driver turned into a socket. At the dealer, they will sometimes charge you labor to remove the manifolds to gain access, but a good technician will know how to get the job done. On realoem u can find this part, its no more than 30 bucks.
silvrXI is offline   Reply With Quote
