Old 10-28-2012, 01:27 AM   #1
dwtaylorpdx
My Ride: 2005 330xi
Have you used waterless coolant in your BMW?
I simply want to know if anybody has run waterless coolant in their BMW E46.
I'm considering the Evans product, I've used it in heavy duty trucks, but that's a bit different than the BMW for load...
The reason is that you run zero pressure in the radiator with it, which I theorize means less pressure and stress on the system... (Good thing...) and its a lifetime product (I've seen trucks with literally millions of miles and 10 years on it.)
It seems like it should work fine, Have to figure out the best way to zero the system, I think the stock radiator cap could be drilled out to disable its pressure holding capability.
Anyway anybody used it?
Dave
dwtaylorpdx is offline   Reply With Quote
Old 10-28-2012, 10:12 AM   #2
Hornung418
My Ride: '04 MB ZHP
You'll find that a 1 bar expansion tank cap is in production right now. While that may reduce stress on the system, the boiling point of the coolant is lowered, albeit not significant to worry about overheating while running 50/50 mix.
Interesting note about the Evan's product, it has a boiling point of 375*F and freezes at -40*F. So in theory you can still use the same thermostat and get the same fuel efficiency from a non pressurized system, without worrying about over heating or rupturing a critical cooling part.
Hornung418 is offline   Reply With Quote
Old 10-28-2012, 06:58 PM   #3
dwtaylorpdx
My Ride: 2005 330xi
I think the neat part is the lack of pressure, many head gasket failures are also aggravated by pressure in the water jacket..
Downside is its going to cost 80 bucks to do... Hoping someone else has played with it! My 05 330 has 100K on it now and
I figure next cooling system service I could do a new radiator and hoses and go withthe Evans...
Dave
Old 10-28-2012, 07:04 PM   #4
Hornung418
My Ride: '04 MB ZHP
Do it and document the results. If you run it pressurized I don't see the problem until you figure out a solution to the cap. You can't just take the Expansion Tank off so you gotta find a no pressure cap.
Sent from my DROIDX using Bimmer App
Old 10-28-2012, 07:08 PM   #5
dwtaylorpdx
My Ride: 2005 330xi
I plan on keeping track of the mileage and drive the car, first my E36 then after I see some time on the parts, the E46 gets the taste... I'm mostly thinking about the aluminum..
Dave
Old 10-30-2012, 01:09 AM   #6
E46_330_Ci
My Ride: 330 Ci 2001
So do we need i non pressurized cap ? my do this tomorrow with a new radiator im adding
E46_330_Ci is offline   Reply With Quote
Old 10-30-2012, 01:43 AM   #7
zander271
My Ride: 6spd ZHP/5sp XI
The PO switched to Evans NPG+ in my ZHP. He even gave me 2 spare bottles of it He also did a full cooling system refresh at 80, I'm at 100k now with no issues. It may extend the life of the cooling system by some but I'm not sure how much in the end. It's all plastic and rubber which the main enemy of these parts is heat and time.
I wonder if Mango will find this post!? It is cooling related.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 11-01-2012, 12:48 AM   #8
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
i use engine ice
hi-perf. coolant.... you put 6 bottles straight in your block..... i like it.. i use it to bring down the heat from my engine for the a/c.. it lower my temp i say a good 15 to 20 degree's...i also put in my car a 55 degree termst. and a clutch fan...i only used this stuff in the past year..... but i like it alot.....it help me in those few very hot daysin the upper 90'ies......sorry i can't give you more in sight of the ice......
bob
bobm3 is offline   Reply With Quote
Old 11-02-2012, 04:51 PM   #9
Jackcat559
My Ride: 2003 530
I used Evans for a little over a year now, with no issues
Jackcat559 is offline   Reply With Quote
Old 11-06-2012, 02:46 AM   #10
wes_rod
My Ride: '01 BMW 325ci
So do u need a pressurized cap for use or a non?
wes_rod is offline   Reply With Quote
Old 11-06-2012, 06:58 PM   #11
Jackcat559
My Ride: 2003 530
Just the stock cap
