Sponsored by BimmerWorld
Old 10-28-2012, 07:56 AM   #1
m5t
My Ride: 325 Ci
Uneven height at rear (oem stock parts)
I have e46 325 Coupe with sport suspension, which is 15mm lower then standard one. After replacing my original 18" wheels with 19 CSL replicas (8.5 square setup) I realized my rear right side is almost an inch is lower then the other, and therefore I'm rubbing quite a bit on that side. I was pretty sure my spring broke, but when I took everything apart yesterday I was surprised to see that spring is fine, shock absorber and all other parts look fine as well.
I need to understand what my next steps are, I don't mind rolling arches afterwards, but first I want to make sure suspension is looking good, and one side being lower is not good
Does shocks have any influence on the height, so I can exclude them right away? So in my case shocks and springs are the original oem ones, springs have 3 grey stripes (hardness). Can springs just wear out, as basically they are almost 10 years old now, can this be the case? Is there anything else that can cause this?
PS I'm attaching the picture from where you can see the height with 18" wheels.
m5t is offline   Reply With Quote
Old 10-28-2012, 08:25 AM   #2
Jperry666
My Ride: 2002 325i 5spd
I had a similar issue with rear ride height being different. My problem was a broken sway bar link. Have you checked those?
Jperry666 is offline   Reply With Quote
Old 10-28-2012, 02:33 PM   #3
chrisbp
My Ride: E46 Coupe
What make and what offset are the wheels and what profile tyres you running ?
chrisbp is offline   Reply With Quote
Old 10-28-2012, 05:46 PM   #4
m5t
My Ride: 325 Ci
Thank you for a hint, how do you check if its broken? B***1091;***1090;***1077; or physically broken into two parts? I guess it will hard to tell whether its bent, but I don't think its physically broken in my case, as I would see it. Also I have wheel alignment few month ago, I'm sure they would see if there was something wrong.
Offset is 37 and they are 8.5. Tyres are 255/35, so they should fit, and I can see this on one side, its just perfect - not too low to rub and not too high. There's a problem with suspension, as 1 inch difference its a lot, so I need to solve that first.
What I noticed few times already, is when putting rear wheels back on the ground from the jack, its actually stays might higher fist and then it goes down. So I don't think spring will do this, this behavior is more related to shocks, no? Unfortunately the only way I can check this, is to replace shocks, but I don't want to do it unless I'm sure they can influence the height level. I'm not saying someone can diagnose this with 100%, but at least in theory. For example I was pretty sure before that only springs are responsible for 'lowering the car', and yes, you might want to match them with shorter and sportier shocks. But can car actually go lower on the same springs if shocks are going bad? Or can the spring become weaker with time, as normally they just brake? Thank you in advance.
PS Adding a picture of my other side which is 'normal'
Old 10-28-2012, 06:00 PM   #5
Jperry666
You would have to visually inspect it. Mine was broken in two. Your bushings could be bad if not physically broken.
Old 11-06-2012, 12:00 PM   #6
Beamer Creamer
My Ride: 2005 bmw m3
Jack car up by mounts and make sure measurement from rim to fender is same. If so sway bar good. I would thimk its a sacked of spring. But also think shock absorber weak or toast could prob put enough extra weight on spring to compress one inch possibly. Are fronts exactly the same? How many miles on shocks and springs?
Beamer Creamer is offline   Reply With Quote
