Sponsored by BAVSOUND
Old 10-28-2012, 07:55 PM   #1
h2m3
My Ride: 2001 330i
Crossed wires: What's the best aux input?
Hi folks,
I recently bought a 2001 330i sedan with Business CD, Harman/Kardon, and no CD changer. There is no "mode" button on the receiver face. There is also a badge in the trunk saying the car is pre-wired for a BMW phone (I have no idea how common this is). After calling the dealership and conducting what I thought to be thorough research, I purchased the USA-SPEC PA12-BMW-DSP, on the assumption that the HK "HiFi" button on the center console indicated the car has DSP.
When I went to install it, I found that the cables provided did not match up with what I found in the trunk of my car, or anything that I'd seen in an installation video. For one thing, the three-pin (white-brown-red) connector had the brown wire in the second position. And the second set of connectors (on the adapter) did not match any of the three other connections present in the trunk of the car. See attached pic of the wires present in the trunk.
What I'm seeking is a hard-wired solution for my iPhone. Having it charge from the same connection would be nice, as would integrated controls, but neither is a must-have. Whether the audio signal travels over Apple dock connector or 3.5mm audio cable doesn't really matter either, but I can't live with an FM modulator.
With this post I hope that someone here can make a recommendation about what solutions will work with this setup, or at least tell me:
Does the HK stereo in the '01 E46's indicate that DSP is present?
Will the Audiovox/DICE Duo/MediaBridge work? If so, do I need the DSP adapter?
How do those devices differ from the Soundplicity kit?
Thanks very much in advance!
h2m3 is offline   Reply With Quote
Old 11-01-2012, 12:24 PM   #2
h2m3
My Ride: 2001 330i
Old 11-01-2012, 05:50 PM   #3
markusmarkus
My Ride: 2001 330Ci
I don't believe DSP was available in the E46. There are several solutions to integrate an iPhone with the stock system. I have a DICE Silverline Pro unit integrated with the oem head unit. It gas worked fine with both an iPhone 3GS and iPhone 5.
Old 11-02-2012, 08:28 AM   #4
h2m3
My Ride: 2001 330i
Thanks markus. Does your car have the HK option?
Old 11-02-2012, 09:11 AM   #5
markusmarkus
My Ride: 2001 330Ci
No it doesn't.
Old 12-16-2012, 08:19 PM   #6
DonaldE
My Ride: 2002 330i
I'm curious about this setup also as I have similar wires in my 2002 330 with Business CD Harmon Kardon speakers and no CD changer. However when running my VIN, I found that I am pre wired for a CD changer. I have these cables and would like to know what they are as well. I have read all the threads I could find and I think I know my only option is aftermarket or a DICE or similar Add-on. Am I wrong?
Here are my Wires in the trunk.
DonaldE is offline   Reply With Quote
Old 01-07-2013, 02:51 PM   #7
nukem22
My Ride: E46 TiAg Coupe
I've never had an iPod, so I used a BMW-aux adapter with a regular MP3 player. I think it's this one (http://www.oemautosound.com/pc-292-8...mw-radios.aspx). It plugs in where the CD changer would be and uses the CD changer aux in. At least you can still use the volume on the wheel.
nukem22 is offline   Reply With Quote
