Old 11-02-2012, 06:50 PM   #21
tystager93
My Ride: 2003 325XI
http://www.diffsonline.com/
I got my LSD for my E36 from here. Im not sure if they do E46 LSD, i know they do opens and build custom ones also its worth a check.
tystager93 is offline   Reply With Quote
Old 12-05-2012, 05:39 AM   #22
Snipez4664
My Ride: '00 328i
I purchased a full M3 rear with swaybar several months ago. i am still unclear about a few things:
1. what has to be modified, if anything, to use a non-m suspension?
2. what change is there to offset?
3. Titaniumcranium said that adjustable camber arms are needed. How far off will the camber be without them?
4. i know the driveshaft has to be shortened, but are there any alternatives that will work? or are adjustable?
On a 2000 328. Any help is greatly appreciated!
Snipez4664 is offline   Reply With Quote
Old 12-05-2012, 09:18 AM   #23
WDE46
My Ride: '13 128i, '04 330Ci
That's all well and good, but shouldn't you have researched this before buying the suspension?
Old 12-05-2012, 02:40 PM   #24
Snipez4664
My Ride: '00 328i
i did research before i bought it and was under the impression that everything would be fine. Since then i have been reading and there has been a lot of confusion on the things i have listed. I will make it work regardless, but want to be as prepared as possible because i only have access to a lift for a couple of days.
for those looking to do this project- it will cost about $1400 if you get a decent deal on parts. $2000 if you replace all mounts, bushings, and ball joints.
Old 12-29-2012, 05:56 AM   #25
love2drive330CI
My Ride: 2001 330CI
Just curious-
If you go with the $2000 cost of parts as indicated by Snipez4664; how much would installation/labor cost by a Indy?
Just want an idea of what someone has paid for the labor after having the parts that Snipez4664 listed.
Thanks.
love2drive330CI is offline   Reply With Quote
