Sponsored by BimmerWorld
Old 10-29-2012, 11:48 AM   #1
ImSoFreaknWhite
My Ride: '06 M3 SMG VERT
Send a message via ICQ to ImSoFreaknWhite Send a message via AIM to ImSoFreaknWhite Send a message via Yahoo to ImSoFreaknWhite
Cross Drilled and Slotted??
So I had the stock rotors on my 2006 M3 vert and just bought a set of cross drilled and slotted rotors off a friend. They had been on his car since November of last year! ever since they have been installed they have been squealing whenever I break. Super loud!! The breaking is great compared to the OEM rotors its just the noise that makes it bad. Any ideas of how ot make it stop squeaking?
P.S. the shop that put them on said that my pads still had about half life on them. idk if that matters, just thought id let you know incase it helps.
Jordan
My Build Thread
l Status Gruppe One-Piece Lip l Anodized CCW Classics w/ Polished Lips l Black Grills/Gills & Emblems l Carbon Fiber Roundels
Status Rear Section l K&N 57 Series CA Intake l OEM JB Hardtop l TM Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL VERT Trunk
ImSoFreaknWhite is offline   Reply With Quote
Old 10-29-2012, 12:06 PM   #2
TrippinBimmer
My Ride: Just Fast!
what pads is on the car? If u just slap ur friends rotors on with ur stock pads and rotor was used. it will make noises...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 10-29-2012, 12:15 PM   #3
ImSoFreaknWhite
Im pretty sure they are the stock pads! So what pads should I get to eliminate the noise?
Jordan
My Build Thread
Old 10-29-2012, 12:22 PM   #4
Foxtrot_Uniform
My Ride: 325Xi
Did you install new pads when you swapped rotors or just use your old ones? If the rotors were worn (the ones you put on) it may take longer for the pads to bed... Did you use anti squeal compound when you put the brake pads on?
Foxtrot_Uniform is offline   Reply With Quote
Old 10-29-2012, 12:32 PM   #5
bohem4e
My Ride: E46
First you need to turn the rotors (or resurface them) after that you install new pads and fallow the proper brake in procedure in order to bed in the brakes as you should... old rotors with old pads... I am surprised the car even stops...
bohem4e is offline   Reply With Quote
Old 10-29-2012, 02:56 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Get blanks.
Old 10-29-2012, 03:44 PM   #7
ImSoFreaknWhite
No i just kept the same pads I had! and yes the drilled ones were worn. And no anti squeal was used.
How much would a resurface cost? and whats the proper break in procedure?
Originally Posted by Solidjake View Post
Get blanks.
Whats that?
Jordan
My Build Thread
Old 10-29-2012, 05:10 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
Blanks have no holes, no slots.
Old 10-29-2012, 05:13 PM   #9
sjacoby112
My Ride: 2002 325ci
or just get ceramic pads. in all cases I've dealt with they don't make any noise
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 10-29-2012, 09:02 PM   #10
ImSoFreaknWhite
I just had those, they look dumb
Jordan
My Build Thread
Old 10-30-2012, 12:42 AM   #11
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
they look hella functional.
did you do the install? if so, do it right. if not, have someone give you a refund.
use antisqueal on the back of the pads. apply it generously. this should eliminate the noises.
after that, bed the brakes. google how to do this. this will match the pads to the rotor surface and make your brakes much more efficient.
Old 10-30-2012, 12:46 AM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
Old 10-30-2012, 09:02 AM   #13
ImSoFreaknWhite
The ones I had on originally were blank with no holes or slots! And ok would they sell anti squeal at like pep boys or something like that? And yes me and a friend did the install together.
Jordan
My Build Thread
Old 10-30-2012, 02:17 PM   #14
peytonracer4
:D
My Ride: '00 328i
Idk call them. I bet they will though. It's commonly used.
You need to bed your brakes afterwards still
Old 10-30-2012, 02:23 PM   #15
HiHoBrian
My Ride: 05 M3
Yes,the sell it at most all parts stores. You can get brake grease to grease the caliper slide pins and contact surfaces between the caliper and caliper mount. Also use antisqueal on the back sides of the pads. If you clean off all the parts well,then lube and antisqueal you will be all set. Bedding the brakes helps also especially if you have a pad like cool carbons or stop techs. Some race pads will almost always squeal,but it is not likely an issue for you.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 10-30-2012, 03:09 PM   #16
ImSoFreaknWhite
Alright thanks for all the information and quick responses guys. Im going to call pep-boys and ask for anti squeal. This weekend take them apart put new pads and the anti squeal on them. Hopefully that will solve the problem.
Is it ok to just buy new OEM pads from the dealership?
Jordan
My Build Thread
Old 10-31-2012, 04:18 PM   #17
lucky_doggg7
My Ride: 2005 M3
Hold the door Fellahs, over the years, I've run plenty of pads on cross drilled rotors and only one pad screeched a bit and they were Cool Carbons from way back in the day. They stopped great but they made a little noise. Pads I've used include Pagid RS-19 Yellow Endurance Pads, Hawk Blue (rough on rotors but they stop well), Porterfield R4-S and the straight R4 pad, which stops incredibly well, but they screech a little bit also. The braking on this R4 pads are amazing. Anyways, that's my two cents on this subject; sorry for rambling.
Old 10-31-2012, 05:21 PM   #18
ImSoFreaknWhite
Thanks for the info, but im just looking for a middle of the road pad that will eliminate the squealing!
whats the name? how much do they cost? and where can I find them?
Jordan
My Build Thread
Old 10-31-2012, 05:57 PM   #19
lucky_doggg7
My Ride: 2005 M3
Ask, and ye shall receive: http://www.porterfield-brakes.com/
Ask for the R4-S compound. I autocross on this and do the occasional Fontuckey AAA Speedway "roval" track day too and find it good enough for my taste, but if you think you need more brake torque, the R4-E is more aggressive but boy oh boy does it produce the goods when you want. You know, Porterfield is in Costa Mesa, just a few hours drive from Sandy Eggo (San Diego). There's all kinds of good stuff up there, there's a English car repair place that always has real Mini Coopers for sale and customer cars on display, there was a Lotus/Lamborghini showroom there, and a bunch of interesting car shops. Heck, stop off at OC Ferrari by South Coast Plaza Mall or the Ferrari and McClaren Dealers off of PCH. Go to Maggiano, a killer Italian Restaurant - you must get the tender steak medallions with capers! Aww, so good! Anyways, sorry for rambling on...
Old 10-31-2012, 07:40 PM   #20
ImSoFreaknWhite
Is that a normal price for a set of brake pads? I thought they were going to be a lot cheaper.
Jordan
My Build Thread
