330 SMG Stuck in reverse - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-29-2012, 03:42 PM   #1
Euro Enginuity
Past Site Sponsor
My Ride: 04 Jetta GLI
Ok im racking my head here
I have a customers 04 330i with SMG here that is stuck in reverse
When it came in I troubleshot it down to the SMG pump. The pump was getting power but not turning on. Waited 3 weeks for a pump to get here and replaced it. Good thing we did because the slave was leaking as well. Get it all wrapped up and pump turns on like it should. Car is still stuck in reverse. If you move the shifter you can here the pump work like it should but no change in the gear indicator.
I can not communicate with the transmission control module. The DME has code 299a communication error to EGS.
I have verified the following.
power at pins 7,1,21,11
ground at pins 5,17
continuity to DME
pin 36 to DME 4
pin 37 to DME 3
Also verified continuity from DME to cluster on the can lines and they are good
Any thoughts?
Euro Enginuity is offline   Reply With Quote
Old 10-30-2012, 07:58 AM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Maybe something bad with the clutch or gearbox? I've heard of some instances of the throw out arm becoming unseated in a manual car...not sure how different the SMG in internally.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 11-02-2012, 10:55 AM   #3
Euro Enginuity
Past Site Sponsor
Quick update, replaced the SMG control module and programmed it which restored communication. Still couldnt switch gears though. Ended up the pump shorted the module and the gear selector sensor on the top of the transmission as well. All is well now.........
