Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 10-29-2012, 05:17 PM   #1
NicenLoW
My Ride: e46 330ci
Raceland coilovers popping noise.
So I installed these on my 02 330ci and I'm getting a popping noise drivers side. The coil sounds like its binding and popping. I jacked up drivers side and moved spring around to mimic the sound.....seems like the upper coil is rubbing the top cap. Is there supposed to be a spring pad between these parts? It looks to me that there should be one?
330ci TiAG
E53 X5 3.0i
NicenLoW is offline   Reply With Quote
Old 10-29-2012, 05:26 PM   #2
SpeedDemon
My Ride: 08 M3/05 ZHP/02 325i
Aren't Raceland coilovers supposed to make all kinds of horrible popping noises?
SpeedDemon is offline   Reply With Quote
Old 10-29-2012, 07:45 PM   #3
fth001
My Ride: 325i, e36m3, s13
Check to see if the washer between the upper spring perch and strut mount is installed. That noise is from the strut mount bearing not seated correctly so the mount makes contact with the spring perch causing the spring to rotate on the coilover itself. Or it just might be Cause Raceland.
fth001 is offline   Reply With Quote
Old 10-29-2012, 09:20 PM   #4
FoxEyes
My Ride: 04' 330i, 96' 328is
the poping is the system clicking into sport mode, it means you will be able to corner faster and harder, push it to the limit
FoxEyes is offline   Reply With Quote
Old 10-30-2012, 12:33 AM   #5
E40SICK
My Ride: 2001 330ci
endlinks? i had issues with mine being lose.
E40SICK is offline   Reply With Quote
Old 10-30-2012, 05:13 AM   #6
bigjae1976
bigjae1976's Avatar
My Ride: A car
The popping noise is your coil over saying, "I'm a piece of sh1t".
Old 11-01-2012, 06:14 PM   #7
NicenLoW
My Ride: e46 330ci
The passenger side is perfect. There's something I don't on different I guess. Is there supposed to be a washer between the top hat of coilovers and the strut mount?
Sent from my SCH-I500 using Bimmer App
330ci TiAG
E53 X5 3.0i
Old 11-01-2012, 06:15 PM   #8
NicenLoW
My Ride: e46 330ci
And once that sound is fixed ill be very pleased with these coilovers.
330ci TiAG
E53 X5 3.0i
Old 11-02-2012, 10:57 PM   #9
NicenLoW
My Ride: e46 330ci
Bump.
Need to figure out if I need the washer or not?
330ci TiAG
E53 X5 3.0i
Old 11-06-2012, 08:53 PM   #10
fth001
Originally Posted by NicenLoW View Post
Bump.
Sorry bro just got back from SEMA. Yes you do need that washer in there. It's part #5 and 6 and goes between the upper strut mount and upper spring perch. http://realoem.com/bmw/showparts.do?...08&hg=31&fg=10
Old 11-07-2012, 11:07 PM   #11
NicenLoW
My Ride: e46 330ci
I just can't find this popping. Almost sounds more like spring binding. I checked over everything, strut mount bearing seems good. Any ideas?
330ci TiAG
E53 X5 3.0i
Old 11-07-2012, 11:14 PM   #12
E40SICK
My Ride: 2001 330ci
have you checked to make sure you endlinks aren't lose?
Old 11-07-2012, 11:48 PM   #13
NicenLoW
My Ride: e46 330ci
Yeah double checked all bolts/nuts everythings tight.
330ci TiAG
E53 X5 3.0i
Old 11-07-2012, 11:50 PM   #14
E40SICK
My Ride: 2001 330ci
dont race lands need short endlinks to begin with?
Old 11-08-2012, 07:51 AM   #15
TnT817
My Ride: 01 330ci
That binding noise is because your strut bearing isn't pressing on the center of the bearing allowing the coil-over to rotate freely. You need to put the proper sized washer in there for the noise to go away. Proper size is enough to touch the inner bearing race and not touch the outer race.
TnT817 is online now   Reply With Quote
Old 11-08-2012, 08:51 PM   #16
NicenLoW
My Ride: e46 330ci
I used my oem washers. Seems to only touch inner race. Basically covers the size of the bearing dust shield. Note* this is only on one side. This weekend I'm a take it all apart again and start from beginning
330ci TiAG
E53 X5 3.0i
Old 11-26-2012, 06:34 PM   #17
CoupeMagic323ci
My Ride: 00 323ci
aaand? prob will get these for xmas. cheap ass gf. oh well better than nothing lol
-Ivan
PS3N ID: siberiasurvivor
CoupeMagic323ci is offline   Reply With Quote
Old 11-26-2012, 11:46 PM   #18
jamex
My Ride: 2005 325Ci
Popping and clunking going straight and not turning and it's not your end links.
Trying to think back to my race land experience. Front end clunk you either didn't torque your strut mounts down proper or you may have included or excluded a washer between the coilovers and the strut mount.
Unbolt one end link if you want to eliminate end kinks as your culprit. Easiy way of knowing if your preloaded from longer end links than you need. Don't drive like a maniac but try to generate the clunking again. Still clunks and it's something else.
jamex is offline   Reply With Quote
Old 11-28-2012, 11:37 AM   #19
Jesse M
My Ride: 05' ZHP
Jesse M is offline   Reply With Quote
