Old 10-30-2012, 11:12 AM   #1
ShermanBG
My Ride: E39 530i; E46 M3
330i automatic gearbox on 325i
Hi guys,
A friend of mine has 325i M54B25 but his automatic transmission has failed. I have a spare automatic gearbox in perfect condition from 330i. Is it possible just to replace the gearbox with torque converter without any trouble and fault codes? As I can see the control units are the same and maybe the gearbox internals are the same just the torque converter of 330i is stronger. Any ideas?
ShermanBG is offline   Reply With Quote
Old 10-30-2012, 03:21 PM   #2
GrafSpee
My Ride: e46 330xi
The 330xi and 325xi has a GM transmission, the 330i and 325i has a ZF.
Software would have to be replaced.
The 330 is longer gears.
Just an update with WinKFP.
GrafSpee is offline   Reply With Quote
Old 10-30-2012, 08:26 PM   #3
ShermanBG
Both cars are rear wheel drive with ZF transmissions. So do you think that 330 gearbox can be fitted? I also have the transmission control unit...
Old 10-30-2012, 08:28 PM   #4
TrippinBimmer
My Ride: Just Fast!
WRONG. My 330i has a GM trans...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 10-30-2012, 08:28 PM   #5
TrippinBimmer
My Ride: Just Fast!
Compare both model number on both tranny but should work fine.
-Anthony
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 10-31-2012, 01:28 AM   #6
GrafSpee
My Ride: e46 330xi
You are right.
In Europe there is the GM transmission (only) for the 330xi.
