Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
Just completed fitting Morimoto mini H1 HID from TRS to stock ZKW halogen lamps.
http://www.theretrofitsource.com/pro...roducts_id=221 The car is not (yet) coded for Xenon, hence flickering/bulb-out warnings on the dash. However, the headlights only flicker with the engine running, while being steady otherwise. The solution is simple: put a capacitor to the low beam wires parallel to the ballast. I used 10000uF 35V electrolytic capacitors from West Florida Components. They sell them for $1.80 each. http://www.westfloridacomponents.com...Category_Code= Mounting the caps is easy, there are two barrel-like spaces right below the headlights. See the pictures attached. *** Note that these are electrolytic capacitors, so follow the correct polarity when hooking them up. *** Last edited by vadim; 07-14-2011 at 09:43 AM. |
#2 | |
#3 | |
As for the place, they don't necessarily have to be mounted there, of course. |
#4 | |
Detail please |
| Tags |
| capacitor, ddm, flicker, hid |
