Old 11-01-2012, 12:36 PM   #21
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Originally Posted by 323tom View Post
I don't have DSS drive shaft I have a custom one SP had made for me, I have DSS axles though...
Oops, figured it was a DSS one.
Old 11-01-2012, 02:04 PM   #22
Bdave
My Ride: M3 HPF Stage 3
Your SP drive shaft could still be a major source of your vibration. Switch to more forgiving motor mounts and go from there. You may be getting vibration from more than one source. You have a lot of new components, some custom. You may have to do a trial of elimination like re installing your OEM drive shaft.
Get several pros to give their opinion. Not saying even they will be able to tell for sure. be persistent and doggedly track it down. Let us know.
I have heard of major NVH coming from unforgiving transmission mounts too. so, you have a lot to consider unfortunately.
I would start with motor mounts and the drive shaft unless some one insists on another route. I am glad I retained my OEM drive shaft. Its the diff brace that is really important....as per Marcus's personal experiences. Thanks for that info Marcus!
Bdave is offline   Reply With Quote
Old 11-01-2012, 05:40 PM   #23
MarcusLSB
Diff brace has its own set of potential issues when used with non oem rear sway bars. My sway bar was binding due to it, so I had to remove the brace. I now run a solid billet custom machined differential cover. I'll post pics later.
Old 11-01-2012, 05:54 PM   #24
Bdave
AH, interesting. I still want that brace and was considering going BACK to the OEM sway bar. I will need LESS bar with a big GTS wing on the trunk according to the aero experts.
So, thats good to know. Is your SAAD brace for sale? PM me.
Old 11-01-2012, 08:13 PM   #25
MarcusLSB
I'll probably hold on to it for the time being. Need to make sure I have no issues with my billet cover holding up.
