Old 11-11-2012, 06:47 PM   #1
Wormydog
My Ride: 1999 BMW 323I
Strange fault codes!!!!!
So, im getting a group of codes that strange to me..."P1250,P1188,P1189,and 1250p"...I have read that the 1250p has something to do with the heater, but ive read somewhere else that its a partner to other codes, and rarely shows up by itself ....So does anybody have any idea what kind of im in?
Wormydog is offline   Reply With Quote
Old 11-11-2012, 07:26 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
P1250 does not appear to be a correct code for your car based upon my reference information at hand?? You may be using a generic code reader that cannot read this code properly??
It may be something to do with your thermostat?
State your year & model.
What they of code reader are you using?
Based upon your current codes I would suggest your read the first link below in my signature.
Old 11-14-2012, 01:44 PM   #3
hoodust
My Ride: Tuned 3 & Drift M3
Send a message via Yahoo to hoodust
I had the same 3 codes before. p1250 is low on fuel. Fill up atleast half of your tank and read the code again it usually disappears. As for the p1188 and 89 check your rubber boots going to the throttle body for any holes or cracks. Replace it, clean your MAF,throttle body and ICV as that did the trick for me. Also check the crank case valve hoses for any leaks as this will give the codes.
under modification DriftUNED
hoodust is offline   Reply With Quote
Old 11-14-2012, 02:11 PM   #4
Wormydog
Ok, everything u sad it spot on to what I've been reading was the solution.Except for the p1250, cause my tank gets filled up once it gets to half left...
Old 11-14-2012, 02:36 PM   #5
jfoj
P1250 is probably an incorrect translation of a manufacturer specific code being picked up by a generic scan tool??
What scan tool are you using?
Old 11-14-2012, 03:43 PM   #6
hoodust
might be a loose gas cap. I cleared my codes multiple times. 1250 shows up when I scan my car with low fuel. Sometimes it doesnt when im half full. I have struggled with the 88 and 89 codes for a month.
I replaced my boots yet it still shows up. So I took took out everything and cleaned the MAF, ICV and throttle body and tighten thr boots with a torque wrench. also chech the air conpressor hoses they might be cracked as well .
