Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Will over stiff coilover decrease grip on bumpy cornering?
Whenever I corner and if the corner is bumpy . The car feel it decrease in grip.
will it because the car is drop low or the coilover damper turn too stiff therefore the car might jump off the road a bit??
![]() missed the ci, welcome the i |
#2 |
Please help solve out the problem guys
#3 |
Its not that simple but if you make the springs stiffer in one end of a car that end usually loosens up/slides easier.
Stiff shocks, more tire pressure, different tirs all add up. Dave |
#4 | |
Also my tire is 28lb front 29lb rear. Dunlop star z1 225/40/18 Is it hard to make a car in air? Since on bumpy road my car jump up...
#5 |
The short answer is yes! When I had PSS9 on full soft there were no issues. When set to full stiff the car, especially in the rear, would bounce around rough corners severly! It appears that your car is very low with very little suspension travel and a very stiff setup. You've created a monster!
#6 | |
Since when I go through rough corners, sometimes I get bounce and understeer off the apex..
#7 |
Understeer off the apex? I'm stiff and low but get oversteer out of the apex. Try adjusting your damping to correct for this. I think you want a stiffer rear for oversteer.
#8 |
There are many factors to consider. I'm running considerably more spring than you in the rear and I have no such problem. In fact, I have less problem with the rear end hopping around over bumpy corners than I did with the stock ZHP setup. Damper capabilities and adjustment make a huge difference as does the overall balance of the car. 8k springs front and rear doesn't sound like an ideal setup to me but there are too may unknowns to be able to resolve your issues. If adjusting the dampers doesn't solve things, you need to find a good local suspension tuner.
