///M3 Forum
Old 11-01-2012, 08:48 PM   #1
///M3.22
My Ride: 2004 M3
Service and Repairs $6,000!!!
So I bought my 2004 m3 into the dealership today as my service light came on and I know I needed rear brakes, brake fluid flush and my washer fluid pump was broke. My car has roughly 62K miles on it and I already had Inspection I and II completed. When I got to the dealership they informed me that I was do for an Inspection service which would run about $1,600, brake fluid flush about $220, rear brakes $780. So this would have cost around $2,600 which is not chump change but reasonable (at least I consider it reasonable since I purchased an expensive car and I expect it to cost a decent amount to maintain).
Then I got the call for the dealership with the laundry list of things that I needed done. Please let me think if you guys think I am completely getting taken advantage of on based on the service and prices:
**All prices include tax and labor**
Tune Up/Inspection Service - 1,778
Wash fluid pump - 227
Rear Brakes (Rotors) - 781
Rear Control Arms - 667
Rear shock mounts - 460
Alignment - 300
Drive Belts - 276
Replace all hoses - 1,598
Total Cost = 6,087
Regarding the suspension I was told that my control arms were bent, could have been from hitting a pot hole or something. Said I didn't need to have it done right away but will cause tires to wear unevenly. Dealership told me my hoses and belts were on their way out. Said hoses were important because it would not be good if they broke and fluid got all over the engine (also said these should be replaced every 5 years).
///M3.22 is offline   Reply With Quote
Old 11-01-2012, 09:04 PM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
Sounds like your car needs a lot of work throughout. Not clear on why you chose to take it to a dealership instead of an Indy shop.
Alan is offline   Reply With Quote
Old 11-01-2012, 09:17 PM   #3
DtrM3
My Ride: 2002 M3
and another falls victim to the bimmer stealerships... ive saved so much money doing the work myself, contrary to beliefs our cars are not that hard to work on, yes they can be a pain in the ass but there are enough diys to fix anything, they wanted 3400 to do my guibo and diff mounts and center support bearing, i found all the parts for 350 bucks online and a 6 pack of beer i bribed some friends to help... 355 vs 3400... pretty obvious there.
DtrM3 is offline   Reply With Quote
Old 11-01-2012, 09:34 PM   #4
djantlive
My Ride: E46 M3
Get another shop to look at it. Some stuff you mentioned are probly not needed.
djantlive is offline   Reply With Quote
Old 11-01-2012, 09:51 PM   #5
Stanc3
Stanc3's Avatar
My Ride: 99' JB 328i
Im assuming it should be lower than half that! I'd definitely take it too an Indy shop, If not, DIY some of this stuff.
- Albert Einstein
- Chad
Old 11-01-2012, 10:11 PM   #6
///M3.22
My Ride: 2004 M3
The problem is I do not have the equipment or know how to do the work myself. Also, with previous car I have had horrible experiences when I do not take the car to the dealership. I am yet to find a reliable mechanic that can work on high end cars. I know they are gonna be more expensive then doing the work myself or at an Indy shop, but I guess I want to know if they are straight up taking me for a ride on this one.
Old 11-01-2012, 10:13 PM   #7
Stanc3
Stanc3's Avatar
Im sure someone from these forums from your area can point you in the right direction. I'd find an Indy 100%.
- Albert Einstein
- Chad
Old 11-01-2012, 10:15 PM   #8
Healthservices
My Ride: 325i 545i
Where are you located? Maybe someone can recommend someone to work on your car?
Sent from my SAMSUNG-SGH-I717 using Bimmer App
Allen
Healthservices is offline   Reply With Quote
Old 11-01-2012, 10:16 PM   #9
Alan
Alan's Avatar
My Ride: 2006 M3
Go to your Regional Forum and get a local recommendation.
Old 11-01-2012, 10:17 PM   #10
nike001
My Ride: Fergo
The hoses and drive belts can be done cheap. Crazy that they'd charge 200+ to replace a damn belt..
Brakes are easy too. Is the valve adjustment incorporated in their tune up price?
2015 M235i 6MT
nike001 is offline   Reply With Quote
Old 11-01-2012, 10:55 PM   #11
olivierE46M3
My Ride: E46 M3 2003
They are f..... you big time!!!!
olivierE46M3 is offline   Reply With Quote
Old 11-01-2012, 11:03 PM   #12
TheRusski
My Ride: gone...
Did they offer anal lube with that?
TheRusski is offline   Reply With Quote
Old 11-01-2012, 11:19 PM   #13
///M3.22
My Ride: 2004 M3
Nike001 - Valve adjustment is included in price
Wow, I guess it is worse then I thought! What would guys say is a reasonable price for all the above mentioned work?
Old 11-01-2012, 11:44 PM   #14
choxor
My Ride: JDM
Can't say since I would just DIY all of it aside from the alignment (nothing wrong with the fact that you're not, though). Price is going to depend somewhat on your location. Like Alan said, start something on the regional forums to find a reputable indy. If you're not a DIYer finding an indy you can trust is a necessity.
Old 11-01-2012, 11:51 PM   #15
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
[QUOTE=///M3.22;14864336]
Alignment - 300
Drive Belts - 276
Total Cost = 6,087
Oh lord help me!
OP, you don't need to be handy to do lots of this. Plugs...lefty loosey...get the right ones. Coolant flush--$20. Belts..$40-50 maybe.
Air, cabin air filters...take 5 mins. fuel filter--don't smoke! Oil...1 hour if you let it drip.
If you don't have a brake pad warning indicator, but $10 caliper and see how much pad material you have left. I think the indicator triggers at around 3 mm of pad material...rotors are easy.
$100 in tools saves you a few thousand against the dealer. A few sleepless nights studying diys/watching vids...you've got a bit of this done.
I haven't done plugs on an M...sounds like it'd be fun! How far are you from the city?
Some fluids take some work, but most are easy.
Oh, and the hoses. I replaced my final engine cooling hose 1,000 miles ago or less...240K miles...mmmmkay?
The hoses don't fail ever, really...the 0-ring might leak at some point...and you should replace them when doing cooling system work since you're there anyway, but if they're not leaking...and they're not...just read cooling threads. You can replace your entire system in parts for $700 I think...and you don't need to anyway. When you learn enough...do the therm, ET, wp, and get the hoses then. Also, btw, by 'all the hoses' I guarantee you they meant 2-3 hoses...not the six you have (I'm pretty sure anyway).
I bet you have $2,000 in parts there if you did everything...less if you find prices at some of our well known sources like bmaparts.
think about it. A 150 piece craftsman tool set gets you to most places you'd go.
Idiots and pregnant women work on their cars here...I think you have the skills even if you don't think you do.
But, if you do give in stupidly to this fantasy wish of the dealer, please videotape your SA's face when you say "okay."
It's a trap!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-01-2012, 11:54 PM   #16
nojoda
My Ride: 06 M3Vert 6MT JB/CIN
dude bail out, look for the reviews and comments of local indy shops.
buy parts online and ebay.
monthly maintence is IMPORTANT and CRUCIAL
2006 BMW M3 VERT 6MT S/C VF570 (CURRENT)
2007 B7 AUDI A4 2.0T CVT FWD (BRILLIANT BLACK) TRADED
2002 E46 BMW M3 SMG II (TIAG) RIP
INSTAGRAM : @itsjorgebrah
nojoda is offline   Reply With Quote
Old 11-02-2012, 12:04 AM   #17
vtn86
My Ride: E46 M3
Best advice here. Too bad you aren't local, I'd do this work for 6k LOL.
Modify your car for a function and purpose, not just to follow the crowd.
vtn86 is offline   Reply With Quote
Old 11-02-2012, 12:09 AM   #18
taylor192
My Ride: 2003.5 M3
$800 for rear brakes?
Rear brakes are < 2hr labour, rotors ~$200/pair and pads < $100/pair. Thus $500 max... yet I bet you don't need rear rotors as the rear rotors wear very slowly. I measured mine and after 70K miles my rear rotors were still good so I just changed pads.
$500 for RSMs?
RSMs are < 2 hrs labour, $30 each. Thus ~$250.
$300 for an alignment?
Mother****. Most alignment shops charge half that.
Replace all hoses, **** that, replace them as they leak. Its just coolant, a leak is not going to do any damage.
The rest seems more fair, still on the high side, yet not as ridiculous. Replacing belts is a good idea at your mileage and age.
Old 11-02-2012, 12:12 AM   #19
///M3.22
My Ride: 2004 M3
I am located on Long Island, in the Commack - Huntington area. I think you guys are right, I need to find a Indy Shop that I can trust, but that is the hard part
Old 11-02-2012, 04:52 AM   #20
MJLavelle
My Ride: 2001 BMW 330ci
Alignment - 300
Drive Belts - 276
Total Cost = 6,087
I just want to get this out of the way first -
Holyfvckingsh!tmotherfvckerc0cksvckersonofab!tchWOW
Sorry for that vulgar explosion, but it was entirely warranted.
This service quote is nearly 1/3 the value of your car! (based on a guick KBB search for Private Sale value, and giving you Excellent condition - about $20k. It is probably worth more in the current market)
Let's start with the biggest issue here, that quote of yours I bolded above. Not to be offensive, but that sounds like some Donald Trump sh!t, except he would not then post about it possibly being a bit high. I am not trying to be insulting (not very well though), and I really don't want to get off on the wrong foot with you, because you seem like you may be an OK guy. But an M3 was an expensive car when new, and you can expect to pay more for parts. You can expect to pay more for service as well, or do it yourself. But you should not expect Pulp Fiction style, gimp in a basement type sodomy as payment for for service. Zed is dead.
But the reality is you purchased a somewhat expensive car, and you are paying damn near Super Car prices to maintain it. You have no reason in the world to expect to pay these sorts of premiums to drive an 8 year old car with 62k on it, unless it has the words Porsche, Aston Martin, or Ferrari on it.
So, your attitude alone needs a major adjustment. This is no longer a World Class vehicle, and never really was. Don't get me wrong, it was, and still is, an amazing car, and I am not taking away one thing from it. It is an engineering marvel. But it is not one that requires huge amounts of money to maintain. So drop the "you gotta pay to play" attitude, unless you like wasting money. And if you do like wasting money, at least get a car that has the prestige to justify that attitude.
There is no shame in not being able to do it yourself. There is a lot of shame in being raped by the dealership.
If it is a matter of not knowing how, you can decide to learn, and there are tons of resources available to teach you how to do it, step by step. You can probably find someone on this forum who would be willing to come help you, either for some money (no where near what the dealership will charge), or for a 6 pack and maybe a steak on the grill afterwards. If you want to go this route, which I strongly recommend, then you can pitch in and help, and start learning. Honestly, if you do not choose to learn to do these things for yourself, or if you do not have the time to do so, you may as well trade your car in for a new one, with service and warranty included. An aging e46 M3 is not the car for you. You are wasting money paying to have this car serviced, and it is not even an investment, it is a loss. A few more services like this, along with what you have already paid, and you have probably exceeded the value of the car. You are sadly mistaken if you think this high rate service will add value when it comes time to sell. It may earn a few chuckles for the buyer though.
If you take the time to search the Internet parts places for the OEM BMW parts being replaced in this estimate, the prices should make you want to puke. They are nowhere near what you have been quoted (I understand the quotes include labor, but the part price breakdown has to be just as ridiculous). With some help, some elbow grease, and smart shopping, you can probably get all of this done for 1/3 of the quoted price.
I would pay Sophia Vergara $220 to flush my brake fluid, if she wore a thong and a smile, but not some dealership tech. With a $90 brake flusher, you could do this yourself for about $40 in fluid. And you would still have the $90 tool left over to do it again next year.
You could get a set of $99 Rouge Engineering rear shock mounts, which are 10x better than what the dealership will install, and have them in within 2 hours, even if it was your first time. They want $460 for a set that will need replaced in about 2 years, if you drive the car a bit hard once in a while.
A set of OEM rear brake rotors will cost you $250 or less. A set of OEM rear pads will cost you $90 or less. They want $781 for that. Even if it took you all weekend to do it, you would still come out at least $500 ahead. Hell, you could go with pads and rotors that are way better than OEM, and still come in under $300 in parts.
I could go on, but it just gets worse. $1600 for new hoses is damn close to criminal fraud. *Sidebar - a burst hose may get fluid all over your engine, as you mentioned, but the MUCH, MUCH bigger issue would the very real possibility of your engine overheating to the point that it is destroyed. That is more like a $8000 - $12000 issue, not a messy engine bay.
I realize that I was not terribly polite, and I was not very delicate in the way I said things, but you are being taken to the cleaners. You may find a good Independent shop, and they may reduce this bill about 30 -40%, but in the end, that is still a lot of money for a car that old. You are past the tipping point to this becoming a losing proposition. You are spending a lot of money that you will never get back in resale. All cars are losing propositions. But if you can afford to pay this kind of money for service, I think it would be worth your while to trade up to a 335 or a new M3, and have the service and warranty repairs covered. It does not seem that keeping the car in top shape is a priority for you. If it was, you would not be getting service estimates like this. I may be wrong. After all, I am drawing an impression from a single post. But if I am right, then this is not the car you should be driving. All e46's, including M3's, are reaching the point that you either need to fix them yourself, or you are losing money at an alarming rate. I am sure there will be people who disagree with me, but from an economic standpoint, it seems to have tipped over into losing territory for owners like you. And that is not an insult. Someone has to be the first owner. Otherwise, people who earn less money would never be able to own these cars. I just think your money will be better spent on new or CPO car payments, rather than paying over the top prices to dealerships or even Indy shops.
Now, exactly what would you sell it for? Maybe we can work a deal!
