Thread Tools Search this Thread Rating: Thread Rating: 25 votes, 5.00 average. Display Modes
Old 11-02-2012, 02:24 AM   #1
adr1an
My Ride: Carbon Black E46 M3
E46 M3 TOP TPS (Throttle Position Sensor) Replacement / DIY / EML
Hi guys - Recently I had my EML light come on. In researching the issue, I found several extremely helpful threads with regards to this light, and possible causes.
The 3rd post HERE was useful to others, and may be useful to you as well.
In my situation, the EML light would pop on while driving, and when I came to a stop, my traction control light would come on and the car would not be allowed to move beyond 2K rpm - aka limp mode. Eventually a check engine light would follow.
Some information about the EML light from the web:
The "EML" warning light in a BMW indicates a problem with the "drive by wire" throttle control system."
"EML" is an acronym for "Elektronische Motorleistungsregelung". Loosely translated from the original German for the BMW owner means Electrionic Engine Power Control.
"EML" is BMW's system name for electronic throttle management. The "EML" system, in it's most basic sense consists of an accelerator pedal (with an electronic position sensor), a computer module (usu. integrated with the main engine computer), and an EDK (Elektronische Drosselklappe or Electronic throttle valve). The EDK is also known as a "drive by wire" throttle. "EDK" throttles use a computer controlled stepper motor rather than a purely mechanical linkage (usu. metal cable attached directly to the accelerator pedal) to control the opening and closing of the throttle plate.
Anyway - I opted to replace the top throttle position sensor, and figured I'd snap some photos on my cellphone in case it might come in handy for someone out there!
If you have been driving, it's a good idea to let the engine cool down. You'll be working near the oil filter, and it's extremely hot.
First, make sure you have a small socket wrench along with a Phillips head bit that fits the screws. The material the screws are made of are fairly soft, and I encountered a few threads where folks stripped them by using an improper size.
The sensor is roughly 54.50 through pelicanparts.com. There isn't much sense in buying this from the dealership for 100.00. Order it online. The part number is listed in this photo: 13-63-7-840-383
This is where the sensor is located:
Remove these two screws:
Here it is removed:
Push down on this metal clip, and release the sensor:
You'll notice the inside of the sensor has a groove - don't worry about this, when you go to install the new one - you will adjust this to the correct position just by mounting the new sensor and turning it into place. Should take very little pressure.
Here it is all finished up. In my case, it looks like the plastic protective tubing around the wires cracked/wore - so I placed some temporary electrical tape on this until I buy some loom to fix it:
I turned my car on and off a couple of times, and my check engine light reset and now I am not receiving an EML light I hope this helps someone else. The other thread I mentioned has some other useful tips and tricks, so if this doesn't solve your problem - make sure to give them a read.
Cheers.
ID:	476411   Click image for larger version
ID:	476412   Click image for larger version
ID:	476413   Click image for larger version
ID:	476415   Click image for larger version
ID:	476416   Click image for larger version
///M3
adr1an is offline   Reply With Quote
Old 04-04-2013, 10:10 AM   #2
2001bimmer330i
My Ride: 2001 BMW 330i
Sorry to post on an old thread but this is a good DIY and easy to follow. I know there are a thousand (and one) threads on Limp Mode, and I have done several of them but not the sensor. I wonder if this has helped others get rid of limp mode, and what code did this fix?
2001bimmer330i is offline   Reply With Quote
Old 04-27-2013, 02:51 AM   #3
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
Thanks for this post. My EML and dsc light turned on under hard acceleration tonight. Pulled a throttle position sensor code. Sounds like it's going to be an easy fix
itscoo2pyopants is offline   Reply With Quote
Old 05-10-2013, 03:15 AM   #4
itscoo2pyopants
My Ride: E53 4.8is
Replaced the top sensor, still getting the light under hard acceleration. Is the sensor under the intake manifold the same part as the top sensor? Saving the pedal for last
Old 05-10-2013, 03:43 AM   #5
cityjohn
My Ride: 2001 M3
Good tip -- I stripped the screw using my BMW toolkit screwdriver!
cityjohn is offline   Reply With Quote
Old 08-20-2013, 09:22 PM   #6
jdub9
My Ride: 2002 M3 vert SMG
I used this DIY a couple of weeks ago, and found my screwdriver bits were too chewed up and were going to strip the screws. Bought a small rachet set and the whole thing took 15 minutes, 10 of which was me trying to test the old switch with an ohmmeter. Car has been just fine since, and actually is much smoother at low speeds and more responsive in the fun zone. The fault code was PO121 THROTTLE / PEDAL POSITION SENSOR A CIRCUIT RANGE, if that helps anyone, although I thought I saw somewhere that you can get that with the other two TPS locations as well. Finally tested the old TPS last weekend with some more appropriate test leads, and it had an open in the midrange, which would explain why I ended up in limp mode.
jdub9 is offline   Reply With Quote
Old 08-20-2013, 09:34 PM   #7
jdub9
Oh, and a great DIY (should have said that first), thanks!
Old 07-13-2014, 02:45 AM   #8
lakal05x
My Ride: 2000 BMW 323i
323i throttle position sensor
Hi guys I was wondering a few things can you find the throttle position sensor in a 323i as you can on this m series? Yesterday since my car has been throwing up EML traction control (dsc) and service engine soon light I decided to take matters into my own hands and look for the sensor since I've been reading up, well I got to the throttle body and couldn't find the sensor. Anyone know where it is? Also I've been looking online for the sensor and all I can find is for m series e46 and older BMWs please help guys I need to get it fixed ASAP as it's my only transportation to work.
lakal05x is offline   Reply With Quote
Old 07-13-2014, 09:57 AM   #9
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
Your TPS are inside the throttle body, you need to get your codes read so you have more information on where to start. Be careful using any M3 DIYs for your car, they are different cars. Once you get codes, post back in a new thread.
ddaniel1 is offline   Reply With Quote
Old 07-13-2014, 11:34 PM   #10
lakal05x
Just another quick question thank you for the quick reply too! Do you know where it'd be possible to find a new throttle position sensor I've looked on summit racing on turners and they have for other year cars but not mine. Any ideas?
Old 07-13-2014, 11:44 PM   #11
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Its a part of the throttle body, not something you can change by itself, throttle bodies are expensive and don't fail often, please post some codes so we know for sure what is going on. If you are referring to the symptoms in this M3 thread you may be off track.
To find parts for your car, the best place to go is realoem, punch in your last digits of your VIN number and it will give you exact part numbers for all parts of your car. Then google those part numbers, some good places for parts are ECS tuning
AutohuazAZ
BMAparts
The link for real oem is:
http://www.realoem.com/bmw/select.do
Be very careful getting parts at autozone or summit etc for BMWs.
Old 07-15-2014, 08:41 PM   #12
lakal05x
Sensor code P0120 throttle/pedal position sensor.
Old 07-15-2014, 09:00 PM   #13
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Here is some info:
http://forum.e46fanatics.com/showthread.php?t=631647
Old 07-15-2014, 09:35 PM   #14
lakal05x
Thank you ddaniel1 for the link I have tried this concept on my car and I did it every time it went into limp mode and for a while it was working but at this point I'll try and try and as soon as I turn on the car it'll throw up Dsc service engine soon and EML.
Old 07-15-2014, 10:26 PM   #15
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Ok, what I would do is remove and clean the heck out of the throttle body and idle control valve, including the electrical connector many DIYs on youtube and on here, you don't have a pedal sensor. If that doesn't work I would get a new throttle body on ebay for 200.00 I would not buy a new one.
I also recommend buying the software and cables off of ebay to turn a laptop into a diagnostic machine.
http://www.ebay.com/itm/BMW-Scanner-...item4ad02c7055
You should have a 20 pin round connector on the passenger side up by the firewall, if so you will need another adapter to use this software, well worth it.
I would also start a new thread on here about the 323i P0120, you will get feedback from others that have tackled this problem. We are hijacking this M3 thread.
Old 11-03-2014, 05:03 PM   #16
rfixed15
My Ride: 2003 E46 m3
My first post :)
I just want to say thank you. Your post has helped me a lot and learn, please continue these badass DYI I really appreciate it.
rfixed15 is offline   Reply With Quote
Old 08-23-2015, 11:24 AM   #17
E46newbee
My Ride: 2000 blow 328i sedan
is the part number the same for a 2000 bow 328i sedan
Here it is removed:
Cheers.
Sorry to post on an old thread but is the part number the same for a 2000 bmw 328i sedan if not how can I find out the right part number_nr_
E46newbee is offline   Reply With Quote
Old 10-28-2015, 03:37 PM   #18
M3J0N
My Ride: See Sig
Send a message via AIM to M3J0N
having a similar problem... at full throttle, I get, yellow brake, DSC, and EML, but no check engine light -straight to limp mode. Thought TPS was the culprit. Bought a new one and OHM tested it very similar to the one on the car. (anyone know what the values should be on the 3 pins??) Replaced it with the new TPS and the car now does the same exact thing, but ALSO throws a P1637 CEL.
-M3J0N
98 M3/4/5Arctic/Dove (Sold)
99 M3/2/5 Titanium/Black (Sold)
04 M3/2/6 Carbon Black/Black (Sold)
95 M3/2/5 Carbon Black/Black (Sold)
95 M3/2/5Avus/Dove Grey 3.2L Swap (Current)
90 M3/2/5 Diamond Black/Black 3.0L Swap (Current)
96 M3/2/5Estoril Blue/Black (Current)
01 325iT Wagon Auto Titanium Silver/Red Sport (Current)
M3Forum Is a Joke (lifetime ban):
http://m3forum.net/m3forum/showthread.php?t=500115
M3J0N is offline   Reply With Quote
Old 11-04-2015, 07:57 PM   #19
M3J0N
My Ride: See Sig
replaced TPS AND throttle actuator and getting the same errors. ANy input on this?
-M3J0N
Old 11-04-2015, 08:40 PM   #20
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Have you reset your throttle adaptations? Might correct it, a good idea to do it anyway with new TPS or gas pedal. Remember there are 3 TPS top, bottom and pedal. My bad pedal caused a hesitation when I punched it, resetting adaptations fixed dying when I stopped or let off gas.
